FlexReport on oracle 4000 charachters limit?
Posted by: jpacini on 8 April 2022, 12:00 pm EST
  • Posted 8 April 2022, 12:00 pm EST
    I get an error when the fields retrieved from Oracle and passed to the report as a C# DataSet are more than 4000 characters long.
    I knew Oracle has some limitations about 4000 characters, but not flexreport.
    I’m using a FlexReportViewer component in an ASP.NET MVC 5 to display the report.
    Can anyone tell me if there is such limitation? I can’t find anything on the guides and documentation
  • Posted 11 April 2022, 4:15 am EST
    Could you please share which type of field you are trying to bind with the 4000 character string?
    Also, please check first if you are able to retrieve the data from the ORACLE to the C# data set correctly.
    Please also share the string that you are trying to bind to the fields.
    Manish Gupta
