Help with converting C1TrueDBGrid code to FlexGrid in ASP.NET application
Posted by: Victor.m.charles.civ on 7 September 2019, 5:04 pm EST
    Posted 7 September 2019, 5:04 pm EST
    I’m using the code below to identify all records in C1AOP5 with the same data in fields selected in C1Box1. How do you modify the code below to accomplish the same using ASP.NET MVC application?
    If CBox1.SelectedItems.Count <> 0 Then
    For Each ColName As [String] In CBox1.SelectedItems
    Dim str As New StringBuilder
    str.Append(“”)
    For i As Integer = 0 To C1AOP5.Splits(0).Rows.Count - 1
    For j As Integer = i + 1 To C1AOP5.Splits(0).Rows.Count - 1
                            If C1AOP5(i, ColName) = C1AOP5(j, ColName) Then
                                If Not str.ToString.Contains(C1AOP5(i, ColName).ToString) Then
                                    str.Append(C1AOP5(i, ColName) + ",")
                                End If
                                Exit For
                            End If
                        Next
                    Next
                    C1AOP5.Columns(ColName).FilterMultiSelect = True
                    C1AOP5.Columns(ColName).FilterSeparator = ","
                    C1AOP5.Columns(ColName).FilterText = str.ToString().Remove(str.Length - 1, 1)
                    TextBox11.Text = C1AOP5.RowCount
                    If TextBox11.Text <> "" Then
                        Panel1.Visible = True
                        C1AOP5.Visible = True
                        '  Label7.Visible = False
                    End If
                Next
                    C1AOP5.Splits(0).DisplayColumns(ColName).HeadingStyle.BackColor = Color.Blue
                    C1AOP5.Splits(0).DisplayColumns(ColName).HeadingStyle.ForeColor = Color.White
                Next
            End If
  • Posted 9 September 2019, 6:08 am EST
    In MVC application, FlexGrid columns has visible property which can be set to true/false to show/hide the column respectively.
    Please refer to the following demo sample for reference:
    https://demos.componentone.com/ASPNET/LearnMvcClient/C1Mvc/WijmoShowPopup/1
    The column can be styled using the cssClass property which accepts the css class name to be applied.
    https://demos.componentone.com/ASPNET/LearnMvcClient/C1FlexGrid/ColumnsStyling
    Hope it helps!
    Manish Gupta
  • Posted 11 September 2019, 7:07 pm EST
    Thank You.
