Help with converting code for C1TrueDBGrid for a FlexGrid in my ASP.NET MVC App
Posted by: Victor.m.charles.civ on 7 September 2019, 7:27 pm EST
  • Posted 7 September 2019, 7:27 pm EST
    I’m using the code below to highlight rows (Green and white) in C1AOP5 and C1AOP40T where both Grids have identical data in their NSN columns. How do I modify the code to achieve the same in two FlexGrids?
    Private Sub C1AOP5_FetchCellStyle(sender As Object, e As C1.Win.C1TrueDBGrid.FetchCellStyleEventArgs) Handles C1AOP5.FetchCellStyle
    'Highlight columns with textbox value
    If apply = True Then
    If C1AOP5(e.Row, e.Col) = FormGlobalMain.TextBox1.Text Then
    e.CellStyle.BackColor = C1AOP5.HighLightRowStyle.BackColor
    e.CellStyle.ForeColor = Color.White
    End If
    End If
    If RadioButton4.Checked And ComboBox2.SelectedIndex = 0 Then
    If e.Col <> 0 Then
    If e.Row <> 0 Then
    For i As Integer = 0 To e.Row - 1
    If C1AOP5(e.Row, 0) = C1AOP5(i, 0) Then
    If C1AOP5(e.Row, e.Col) = C1AOP5(i, e.Col) Then
    e.CellStyle.BackColor = Color.Green
    End If
    End If
    Next
    End If
    If e.Row <> C1AOP5.Splits(0).Rows.Count - 1 Then
    For i As Integer = e.Row + 1 To C1AOP5.Splits(0).Rows.Count - 1
    End If
    End If
    Next
    End If
    End If
    End If
    End Sub
    Private Sub C1AOP5_FetchRowStyle(sender As Object, e As C1.Win.C1TrueDBGrid.FetchRowStyleEventArgs) Handles C1AOP5.FetchRowStyle
        Try
            Dim checkCols As String = yx
            If checkCols.Count > 0 Then
                Dim tempRow = C1AOP5.FocusedSplit.Rows.OfType(Of C1.Win.C1TrueDBGrid.BaseGrid.ViewRow).ToList()
                Dim flag As Boolean = False
                Dim origItem As String = ""
                For Each item As String In checkCols.Split(","c)
                    origItem = origItem + C1AOP5(e.Row, item.Trim("'"c)).ToString()
                Next
                For j As Integer = 0 To tempRow.Count - 1
                    Dim tempItem As String = ""
                        tempItem = tempItem + C1AOP5(j, item.Trim("'"c)).ToString()
                    Next
                    If Not flag AndAlso e.Row <> j Then
                        If origItem = tempItem Then
                            flag = True
                        End If
                    End If
                Next
                If flag Then
                    e.CellStyle.BackColor = Color.DarkGreen
                End If
            Else
            End If
        Catch
            ccc = 1
            Exit Sub
        End Try
    End Sub
    Private Sub C1AOP5_SelChange(sender As Object, e As CancelEventArgs) Handles C1AOP5.SelChange
    s.Clear()
    For Each row In Me.C1AOP5.SelectedRows
    s.Add(C1AOP5.Columns(“NSN”).CellText(row))
    Next
    C1AOP40T.Refresh()
    For i As Integer = 0 To C1AOP40T.Splits(0).Rows.Count - 1
    If s.Contains(C1AOP40T.Columns(“NSN”).CellText(i)) Then
    C1AOP40T.SelectedRows.Add(i)
    End If
    If s.Count = 0 Then
    C1AOP40T.SelectedRows.Clear()
    End If
    Next
    e.Cancel = True
    End Sub
    Private Sub C1AOP40T_FetchRowStyle(sender As Object, e As FetchRowStyleEventArgs) Handles C1AOP40T.FetchRowStyle
    Try
                Dim tempRow = C1AOP40T.FocusedSplit.Rows.OfType(Of C1.Win.C1TrueDBGrid.BaseGrid.ViewRow).ToList()
                    origItem = origItem + C1AOP40T(e.Row, item.Trim("'"c)).ToString()
                Next
                        tempItem = tempItem + C1AOP40T(j, item.Trim("'"c)).ToString()
                    Next
                            flag = True
                        End If
                    End If
                Next
                If flag Then
                End If
            Else
            End If
        Catch
            ccc = 1
            Exit Sub
        End Try
  • Posted 9 September 2019, 7:20 am EST
    Hi Victor,
    In MVC FlexGrid, there is formatItem event which can be used to style the cells based on some condition check.
    Please refer to the following demo sample for reference:
    https://demos.componentone.com/ASPNET/LearnMvcClient/C1FlexGrid/CustomCells/1
    Hope it helps!
    Manish Gupta
