Help with converting code in DataGridView to FlexGrid in ASP.NET MVC App
Posted by: Victor.m.charles.civ on 7 September 2019, 6:14 pm EST
    Posted 7 September 2019, 6:14 pm EST
    I using the code below to search data in C1AOP5 by entering multiple values in one more rows in the AOP6A DataGrid. How do you modify the code to achieve the same with a FlexGrid in an ASP.NET MVC application? Button click event activates AOP6VIEW method.
    For example, if I enter BEL,USA in Row1 and 10411 in Row2, C1AOP5 should display all the records where both BEL and USA are included in 10411 from C1AOP5.
    If possible please send me a sample project with the solution.
    Private Sub AOP6A_CellValueChanged(sender As Object, e As System.Windows.Forms.DataGridViewCellEventArgs) Handles AOP6A.CellValueChanged
    If e.ColumnIndex = 0 Then
    If AOP6A.Columns(e.ColumnIndex).Name = “CheckBoxColumn” Then
    Dim checkCell As DataGridViewCheckBoxCell =
    CType(AOP6A.Rows(e.RowIndex).Cells(“CheckBoxColumn”),
    DataGridViewCheckBoxCell)
    If CType(checkCell.Value, [Boolean]) = True Then
    AOP6A.Rows(e.RowIndex).Cells(“CheckBoxColumn”).Style.BackColor = Color.Blue
    AOP6A.Rows(e.RowIndex).Cells(“CheckBoxColumn”).Style.SelectionBackColor = Color.Blue
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.BackColor = Color.Blue
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.SelectionBackColor = Color.Blue
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.ForeColor = Color.White
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.SelectionForeColor = Color.Blue
    Else
    AOP6A.Rows(e.RowIndex).Cells(“CheckBoxColumn”).Style.BackColor = Color.White
    AOP6A.Rows(e.RowIndex).Cells(“CheckBoxColumn”).Style.SelectionBackColor = Color.White
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.BackColor = Color.White
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.SelectionBackColor = Color.White
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.ForeColor = Color.Black
    AOP6A.Rows(e.RowIndex).DefaultCellStyle.SelectionForeColor = Color.Black
    End If
    AOP6A.Invalidate()
    End If
    End If
    Try
    If AOP6A.Columns(e.ColumnIndex).Name = “Colfilter” Then
    CType(AOP6A.Rows(e.RowIndex).Cells(“Colfilter”),
    For i As Integer = 0 To Me.AOP6A.Columns.Count - 1
    AOP6A.Rows(e.RowIndex).Cells(i).Style.BackColor = Color.Blue
    AOP6A.Rows(e.RowIndex).Cells(i).Style.SelectionBackColor = Color.Blue
    Next
    Else
    For j As Integer = 0 To Me.AOP6A.Columns.Count - 1
    AOP6A.Rows(e.RowIndex).Cells(j).Style.BackColor = Color.White
    AOP6A.Rows(e.RowIndex).Cells(j).Style.SelectionBackColor = Color.White
    Next
    End If
    AOP6A.Invalidate()
    End If
    Catch ex As Exception
    MessageBox.Show(ex.Message)
    End Try
    End Sub
    Private Sub AOP6VIEW()
    Dim filtersourcedatatable As DataTable = AOP6A.DataSource 'Top grid in which filter criteria is entered
    Dim destdatatable As DataTable = C1AOP5.DataSource
    Dim commonality As IEnumerable(Of DataRow)
    Dim lastqry = From theRow In destdatatable.AsEnumerable()
    Select theRow
    lastqry = GetIntersection(filtersourcedatatable, lastqry) 'And operator
    Dim dtclone = destdatatable.Clone()
    dtclone.Clear()
    For Each drow As DataRow In lastqry
    dtclone.ImportRow(drow)
    Next
    If dtclone.Rows.Count = 0 Then
    MsgBox(“No Records Found in AOP-6”)
    C1AOP5.Visible = False
    End If
    If dtclone.Rows.Count <> 2000 Then '2000 isTotal Rows in table
    TEST = 1
    C1AOP5.Visible = True
    Me.C1AOP5.DataSource = dtclone
    Else
    End If
    End Sub
    Victor
  • Posted 9 September 2019, 7:15 am EST
    Hi Victor,
    The MVC FlexGrid is different then the C1TrueDBGrid. In the FlexGrid, there is collectionView which can be used to filter the Data.
    Please refer to the following demo sample for reference:
    https://demos.componentone.com/ASPNET/LearnMvcClient/C1Mvc/CVChaining
    Hope it helps! If not, please elaborate your requirement or share the images for your requirement.
    Manish Gupta
  • Posted 11 September 2019, 7:04 pm EST
    Thank You.
  • Posted 24 September 2019, 9:48 pm EST
    Manish,
    I am using the code below to view data in a table and WebGrid. How do I modify it to view the data in a FlexGrid? I would like to load the data in a FlexGrid and filter the data using selections from multiple column headers.
    1. Homecontroller.cs
      using MVCApp.Models;
      using System;
      using System.Collections.Generic;
      using System.Linq;
      using System.Web;
      using System.Web.Mvc;
      using DataLibrary;
      using static DataLibrary.BusinessLogic.EmployeeProcessor;
    namespace MVCApp.Controllers
    public class HomeController : Controller
    public ActionResult Index()
    return View();
        public ActionResult About()
            ViewBag.Message = "Your application description page.";
            return View();
        public ActionResult Contact()
            ViewBag.Message = "Your contact page.";
            return View();
        public ActionResult ViewEmployees()
            ViewBag.Message = "Employees List";
            var data = LoadEmployees();
            List<EmployeeModel> employees = new List<EmployeeModel>();
            foreach (var row in data)
                employees.Add(new EmployeeModel
                    EmployeeId = row.EmployeeId,
                    FirstName = row.FirstName,
                    LastName = row.LastName,
                    EmailAddress = row.EmailAddress,
                    ConfirmEmail = row.EmailAddress
            return View(employees);
        public ActionResult SignUp()
            ViewBag.Message = "Employee Sign Up";
            return View();
        [HttpPost]
        [ValidateAntiForgeryToken]
        public ActionResult SignUp(EmployeeModel model)
            if (ModelState.IsValid)
                int recordsCreated = CreateEmployee(model.EmployeeId,
                    model.FirstName,
                    model.LastName,
                    model.EmailAddress);
                return RedirectToAction("Index");
            return View();
    1. ViewEmployees.cshtml
    @model IEnumerable<MVCApp.Models.EmployeeModel>
    ViewBag.Title = “ViewEmployees”;
    Layout = null;
    var grid = new WebGrid(canPage: true, rowsPerPage: 4);
    grid.Bind(source: Model);
    View Employees
    @Html.ActionLink("Create New", "SignUp")
    @foreach (var item in Model)
        <tr>
            <td>
                @Html.DisplayFor(modelItem => item.EmployeeId)
            </td>
            <td>
                @Html.DisplayFor(modelItem => item.FirstName)
            </td>
            <td>
                @Html.DisplayFor(modelItem => item.LastName)
            </td>
            <td>
                @Html.DisplayFor(modelItem => item.EmailAddress)
            </td>
        </tr>
    @grid.Table(
         tableStyle: "table table-responsive table-bordered",
         columns: grid.Columns(
             grid.Column(columnName: "EmployeeId", header: "EmployeeId"),
             grid.Column(columnName: "FirstName", header: "First Name"),
             grid.Column(columnName: "LastName", header: "Last Name"),
             grid.Column(columnName: "EmailAddress", header: "EmailAddress")
    @Html.DisplayNameFor(model => model.EmployeeId) @Html.DisplayNameFor(model => model.FirstName) @Html.DisplayNameFor(model => model.LastName) @Html.DisplayNameFor(model => model.EmailAddress)
    Victor
  • Posted 25 September 2019, 12:53 am EST
    Hello Victor,
    In your case, you have set the Layout to null, so the Code to show the C1FlexGrid in cshtml page would be as follows:
        ViewBag.Title = "ViewEmployees";
    [b]@Html.C1().Styles()
    @Html.C1().Scripts().Basic()[/b]
    @model IEnumerable<FlexGridIntro.Controllers.EmployeeModel>
    <h2>ViewEmployees</h2>
    [b]@(Html.C1().FlexGrid().Id("grid").Bind(Model).AutoGenerateColumns(false)
                .Columns(c =>
                    c.Add().Binding("EmployeeId").Header("EmployeeId");
                    c.Add().Binding("FirstName").Header("First Name");
                    c.Add().Binding("LastName").Header("Last Name");
                    c.Add().Binding("EmailAddress").Header("EmailAddress");
    )[/b]
        @item.EmployeeId @item.FirstName
    [b]@Html.C1().DeferredScripts()[/b]
    Hope it helps!
    Manish Gupta
  • Posted 25 September 2019, 10:51 am EST
    Thanks for the code, which classes do I need to add to use FlexGrid in my application?
    Receiving errors: “The type or namespace ‘FlexGridIntro’ could not be found”
    “FlexGridIntro.Controllers.EmployeeModel> does not containa definition and accessible extension metho ‘C1’ accespting a first argument…”
    Victor
  • Posted 26 September 2019, 4:43 am EST
    How do I add C1Mvc/CVChaining.js in my ASP.NET MVC project?
    // This file locates: “Scripts/Lesson/C1Mvc/CVChaining.js”.
    c1.documentReady(function () {
    // a CollectionView based on the raw data
    var view = c1.getService(“collectionView”);
    // create a second CollectionView based on the first one
    var view2 = new wijmo.collections.CollectionView(view.items, {
        collectionChanged: function (s) {
            var cnt = document.getElementById('cnt');
            cnt.textContent = wijmo.format('{length:n0}', s.items)
    // bind a grid to the second CollectionView
    var theGrid = wijmo.Control.getControl('#theGrid');
    theGrid.itemsSource = view2;
    // update the filter on the first CollectionView when the text changes
    document.getElementById('theFilter').addEventListener('input', function (e) {
        // update first CollectionView's filter
        var filterText = e.target.value.toLowerCase();
        view.filter = function (item) {
            return filterText
            ? item.Country.toLowerCase().indexOf(filterText) > -1
            : true;
        // update second collection view's sourceCollection
        view2.sourceCollection = view.items;
  • Posted 26 September 2019, 7:54 am EST
    Hi Victor,
    In your project C1.Web.Mvc dll should be reference either from local machine or Nuget.
    Please refer to the following documentation for reference to include C1 Controls in your application:
    http://help.grapecity.com/componentone/NetHelp/c1mvchelpers/webframe.html#CreatingaNewProject.html
    http://help.grapecity.com/componentone/NetHelp/c1mvchelpers/webframe.html#RegisteringResources.html
    http://help.grapecity.com/componentone/NetHelp/c1mvchelpers/webframe.html#DeferredScripts.html
    http://help.grapecity.com/componentone/NetHelp/c1mvchelpers/webframe.html#AddingControlsinRazor.html
    Please use the following code line instead of “@model IEnumerable<FlexGridIntro.Controllers.EmployeeModel>”
    You may use the script code in your CSHTML page or add a js file in your project and put the code in newly added file.
    In case the code is added in js file, js file should be referenced in the CSHTML file.
    Hope it helps!
    Manish Gupta
  • Posted 26 September 2019, 9:28 am EST
    Manish,
    Below is the complete code in my project, not including references. The code for the FlexGrid should be included in 2c. I will include the .js file in the Script folder and let you know if it works.
    3 Projects: 1. Data Library, 2. MVC, 3. MVCDemoDB
    1. Data Library (Class Library.NET Framework)
      a. SqlDataAccess.cs
      using System.Linq;
      using System.Text;
      using System.Threading.Tasks;
      using Dapper;
      using System.Configuration;
      using System.Data;
      using System.Data.SqlClient;
    namespace DataLibrary.DataAccess
    public static class SqlDataAccess
    public static string GetConnectionString(string connectionName = “MVCDemoDB”)
    return ConfigurationManager.ConnectionStrings[connectionName].ConnectionString;
        public static List<T> LoadData<T>(string sql)
            using (IDbConnection cnn = new SqlConnection(GetConnectionString()))
                return cnn.Query<T>(sql).ToList();
    b. EmployeeProcessor.cs
    using DataLibrary.DataAccess;
    using DataLibrary.Models;
    using System;
    using System.Linq;
    using System.Text;
    namespace DataLibrary.BusinessLogic
    public static class EmployeeProcessor
    public static List LoadEmployees()
    string sql = @“select Id, EmployeeId, FirstName, LastName, EmailAddress
    from dbo.Employee;”;
            return SqlDataAccess.LoadData<EmployeeModel>(sql);
    c. EmployeeModel.cs
    using System;
    using System.Linq;
    using System.Text;
    namespace DataLibrary.Models
    public class EmployeeModel
    public int Id { get; set; }
    public int EmployeeId { get; set; }
    public string FirstName { get; set; }
    public string LastName { get; set; }
    public string EmailAddress { get; set; }
    1. MVC
      a. EmployeeModel.cs
      using System;
      using System.ComponentModel.DataAnnotations;
      using System.Linq;
      using System.Web;
    namespace MVCApp.Models
    public string Password { get; set; }
    b. HomeController.cs
    using System;
    using System.Linq;
    using System.Web;
    using DataLibrary;
    return View();
    c. ViewEmployee.cshtml
    Layout = null;
    var grid = new WebGrid(canPage: true, rowsPerPage: 10);
    View Employees
    @Html.ActionLink("View Employees", "SignUp")
    @grid.Table(
    tableStyle: “table table-responsive table-bordered”,
    grid.Column(columnName: “EmployeeId”, header: “EmployeeId”),
    grid.Column(columnName: “FirstName”, header: “First Name”),
    grid.Column(columnName: “LastName”, header: “Last Name”),
    grid.Column(columnName: “EmailAddress”, header: “EmailAddress”)
    1. MVCDemoDB (SQLServer)
      Employee.sql
  • Posted 26 September 2019, 10:04 am EST
    Manish,
    Below is the code in the EmployeeModel.cs. Should some code be included in that file?
    using System;
    using System.Linq;
    using System.Web;
  • Posted 26 September 2019, 10:53 am EST
    Still can’t reference the required files to avoid this error. Is it possible to send me a sample projects that includes all the required files, or instructions on how to include them in the project?
    Victor
  • Posted 26 September 2019, 1:33 pm EST
    Manish,
    I noticed in the link below, Componentone controls can also be added in templates section of Visual studio, but don’t see that option in my VS, how do you as Component as a template in VS?
    https://www.youtube.com/watch?v=9o4hOJ406V8&spfreload=10
    Please take a look at this, it may be a solution to also use the FlexGrid.
    Victor
  • Posted 27 September 2019, 2:19 am EST
    Hi Victor,
    Please find the attached sample for reference.
    Have you installed the ComponentOne Enterprises on your machine?
    If not, please install the ComponentOne Enterprises on your machine. The installer can be get from the following link:
    https://www.grapecity.com/componentone-studio
    Further, you may create a project using the C1Template and add the Control using the C1Scaffolding.
    Please refer to the following documentation:
    Create Project using C1Template: http://help.grapecity.com/componentone/NetHelp/c1mvchelpers/webframe.html#Using%20C1%20Template.html
    Insert/Update control using C1Scaffolding:
    http://help.grapecity.com/componentone/NetHelp/c1mvchelpers/webframe.html#ScaffoldinginASP.NETMVCControls.html
    Hope it helps!
    Manish Gupta
    FlexGridIntro-EmployeeModel.zip
