Help with using Dropdown control to access PDF
Posted by: Victor.m.charles.civ on 7 September 2019, 3:24 pm EST
    Posted 7 September 2019, 3:24 pm EST
    I’m using the code below in VB.NET to access PDFs from a dropdown control. How do I modify it to work with the ASP.NET C1Dropdown control version? I’m using an ASP.NET MVC application.
    If Trim(ComboBox4.Text) = “Component” Then
    Process.Start(Application.StartupPath & “\Component.pdf”)
    End If
    Victor
  • Posted 9 September 2019, 6:03 am EST
    Hi Victor,
    The MVC application allows to export FlexGrid to PDF directly at Client Side, you may call the export method at on Button Click or ComboBox selectedIndex Changed.
    Please refer to the following demo sample for reference:
    https://demos.componentone.com/ASPNET/MVCExplorer/FlexGrid/PDFExport
    Also, if you would like to access the PDF from the ServerSide to client-side, you need a callback on ComboBox selected index changed.
    Please refer to the following demo sample of the ComboBox for reference:
    https://demos.componentone.com/ASPNET/LearnMvcClient/C1Input/ComboBox
    Hope it helps!
    Manish Gupta
  • Posted 9 September 2019, 11:30 pm EST
    Thank you. Is it possible to send me sample project along which dlls I need to reference in the project?
  • Posted 10 September 2019, 3:34 am EST
    Hi Victor,
    Please find the attached sample. The sample required the C1.Web.Mvc dll. C1 MVC edition should be installed on your machine. Alternatively, it can be installed from the Nuget.
    Manish Gupta
    FlexGridFilter-PDF Export-ComboBox.zip
  • Posted 11 September 2019, 3:05 pm EST
    Thank You.
