How to adjust row height on Flexgrid (Ideally with CSS)?
Posted by: travis on 19 August 2019, 2:31 pm EST
  • Posted 19 August 2019, 2:31 pm EST - Updated 29 September 2022, 10:51 am EST
    So, I’ve attempted to apply CSS formatting to the rows on a flexgrid.
    My CSS looks like this (it’s stupid formatting only to try and see if it works):
    .grid {
        background-color: green;
    .grid .wj-row
        background-color: blue;
        height: 150px;
    .wj-cells .wj-cell {
        background-color: yellow ;
        height: 150px;
        padding: 10px;
    .grid .wj-row .wj-cell {
        background: pink;
        text-align: center !important;
        height: 150px;
    Most of that formatting applies, but the row height is always overridden by the inline styling (image attached).
    The flexgrid setup looks like this:
        @(Html.C1().FlexGrid(Of OrderDetail)() _
                            .Id("flexGrid") _
                            .AutoGenerateColumns(False) _
                            .Bind(Function(ib) ib.Bind(Model.Details).NewItemCreator("SetDefault").Update(Url.Action("GridUpdate", "Order")).Create(Url.Action("GridCreate", "Order")).Delete(Url.Action("GridDelete"))) _
                            .IsReadOnly(False) _
                            .CssClass("grid") _
                            .AllowDelete(True) _
                            .AllowAddNew(True).ItemFormatter("SVGFormatter") _
                            .Columns(Sub(bl)
                                         bl.Add(Sub(cb) cb.Binding("OrderID").Header("OrderID").Width("1.5*").IsReadOnly(True))
                                         bl.Add(Sub(cb) cb.Binding("Picture").Header("Picture").Width("1.5*").IsReadOnly(True))
                                         bl.Add(Sub(cb) cb.Binding("Series").Header("Series").Width("1.5*").Name("Series"))
                                         bl.Add(Sub(cb) cb.Binding("ColorID").Header("ColorID").Width("1.5*").Name("ColorID"))
                                         bl.Add(Sub(cb) cb.Binding("Quantity").Header("Quantity").Width(".5*").Name("Quantity"))
                                         bl.Add(Sub(cb) cb.Binding("Width").Header("Width").Width(".5*").Name("Width"))
                                         bl.Add(Sub(cb) cb.Binding("Height").Header("Height").Width(".5*").Name("Height"))
                                         bl.Add(Sub(cb) cb.Binding("MatchingBack").Header("MatchingBack").Width("*").Name("MatchingBack"))
                                         bl.Add(Sub(cb) cb.Binding("Hinges").Header("Hinges").Width("*").Name("Hinges"))
                                         bl.Add(Sub(cb) cb.Binding("Fingerpull").Header("Fingerpull").Width("*").Name("Fingerpull"))
                                         bl.Add(Sub(cb) cb.Binding("SquareEdge").Header("SquareEdge").Width("*").Name("SquareEdge"))
                                         bl.Add(Sub(cb) cb.Binding("SqFt").Header("SqFt").Width("*").IsReadOnly(True))
                                         bl.Add(Sub(cb) cb.Binding("TotalPrice").Header("Total").Width("*").IsReadOnly(True))
                                     End Sub)
  • Posted 20 August 2019, 3:09 am EST
    Hello Travis,
    To change Row height using CSS, please use the following CSS code snippet:
    .grid .wj-cell{
      padding: 65px 6px;
    Please refer to the following demo sample for reference:https://jsfiddle.net/pkrg6L8m/
    Hope it helps!
    Manish Gupta
  • Posted 23 August 2019, 11:13 am EST
    That’s helpful, thanks.
    I’m still having a hard time getting the formatting to apply as I expect, and I’m confused. I see that the divs that make up each cell have the class set, but then for some reason they also inline style after that. It looks like the inline styling for the elements is using the data from .wj-cell, and as such I can’t override the header style with .wj-header.
    Any thoughts?
  • Posted 26 August 2019, 11:14 pm EST
    The Cells have inline style regarding the Cell position as Top, Left, width and height. These are calculated according to the wj-cell styles (include padding, fontSize etc).
    The headers are also the cell and contains the wj-cell class. If you have applied styles to the wj-cell only, it will be displayed in the headers too.
    To style header differently, please use the following CSS:
    .wj-cell.wj-header{
        font-style: italic; // you may use the !important to override the default CSS
    Hope it clears!
    Manish Gupta
