Olap - DataEngineWebpi
Posted by: mhillar on 14 March 2019, 4:54 pm EST
  • Posted 14 March 2019, 4:54 pm EST
    HI,
    In tootorial to create dataengineWebApi is hardcoded definision in startup.cs this,
        app.UseDataEngineProviders()
                   .AddDataEngine("complex10", () =>
                       return ProductData.GetData(100000);
    It is possible to create dynamic this,
    I would like use prcedure to generate Engine like this and sent some params to controller where should be recreate(remove and create new dataEngine)
                using (var con = new SqlConnection(ConfigurationManager.ConnectionStrings["ConnectionString"].ConnectionString))
                    using (var cmd = new SqlCommand("Get_OLAP_DATA_proc", con))
                        cmd.Parameters.Add(new SqlParameter("@p_FormID", "CCT"));
                        cmd.Parameters.Add(new SqlParameter("@p_UserId", "SA"));
                        cmd.Parameters.Add(new SqlParameter("@p_Params", 1));
                        cmd.CommandType = CommandType.StoredProcedure;
                        con.Open();
                        // var object1 = RunTimeClass.CreateNewObject(table);
                       .AddDataEngine("complex10", cmd);
                        //.AddDataSource("dataset10", () => ProductData.GetData(100000).ToList())
                        //     .AddCube("cube",
                        //     @"Data Surce=http://ssrs.componentone.com/OLAP/msmdpump.dll;Provider=msolap;Initial Catalog=AdventureWorksDW2012Multidimensional",
                        //         "Adventure Works");
    It is possible can you give me some advance?
    thx,
    Maciej
  • Posted 15 March 2019, 12:56 am EST
    We are sorry for the inconvenience.
    Please refer to the following documentation for information regards the Managing Data Source.
    http://help.grapecity.com/componentone/NetHelp/c1webapi/webframe.html#DataSourceManager.html
    Please refer to the following sample link and download which shows how the Data can be fetched directly from SQL server.
    https://www.grapecity.com/en/samples/asp-net-web-api-sales-analysis
    Hope it helps!
    Manish Gupta
