Press "Enter" go to new line in TextArea in grid
Posted by: 1728884346 on 27 March 2018, 5:54 am EST
    Posted 27 March 2018, 5:54 am EST
    I have a grid and contain text area, when i type in this text area and i press "Enter", i want to go to new line in text area, but currently it jump out the text area.
  • Posted 29 March 2018, 2:49 am EST
    We are sorry for the delayed response.
    As default Enter key used for selecting next row and finish editing if cell is in edit mode.
    To overcome this, you need to set keyActionEnter property to None or handle FlexGrid keydown event as follows and prevent default behavior for enter key.
    Please refer to the following sample code snippet:
    grid.hostElement.addEventListener('keydown',function(e){
    	if(grid.editRange){
    		e.preventDefault();
    		e.stopImmediatePropagation();
    },true);
    ~Manish
  • Posted 3 April 2018, 11:40 pm EST - Updated 29 September 2022, 10:59 am EST
    Hi Manish
    I have try to add KeyActionEnter as None, but it not work, if i press Enter, it still end the editing.
    Could you help to provide a demo about this?
  • Posted 5 April 2018, 8:23 am EST
    We are sorry for the inconvenience.
    We need to handle keydown event for Textarea it self and prevent further event for Enter key. Add new line for TextArea by code.
    Please use the following code snippet where input is TextArea reference:
    input.addEventListener("keydown", function (e) {
                    if (e.keyCode == 13) {
                        e.preventDefault();
                        var _val = e.target.value;
                        e.target.value = _val + '\n';
                }, true)
    For your information, from build 4.0.20183.150, multi line support has been added by setting Column’s multiLine property to true same as excel.
    Please use the following code snippet for the same:
     var grid = wijmo.grid.FlexGrid.getControl("#grid");
            grid.columns[1].multiLine = true;
    ~Manish
  • Posted 10 April 2018, 1:55 am EST - Updated 29 September 2022, 10:59 am EST
    Hi Manish
    sorry for trouble, could you help to build a demo about how multiple line work? I don’t know how use, and i try something, but not work.
    and latest ComponentOne Version: 20181.1.17
    I saw below info, but don’t know how to use
  • Posted 11 April 2018, 5:17 am EST
    You need to handle ClientSide to allow in-built multi line editing. Please refer to the following code snippet for the same:
    <script>
        c1.documentReady(function () {
            grid.columns.getColumn("ProductName").multiLine = true;
    </script>
    @(Html.C1().FlexGrid().Id("grid").AllowResizing(AllowResizing.Rows).Bind(b => b.Bind(Model))
                    .AutoGenerateColumns(false)
                    .Columns(c =>
                        c.Add(cb => cb.Binding("ProductID").Width("200"));
                        c.Add(cb => cb.Binding("ProductName").Width("200"));
                        c.Add(cb => cb.Binding("SupplierID").Width("200"));
                        c.Add(cb => cb.Binding("QuantityPerUnit").Width("200"));
                        c.Add(cb => cb.Binding("UnitPrice").Width("200"));
                        c.Add(cb => cb.Binding("UnitInStock").Width("200"));
                .Height("650px"))
    ~Manish
