Posted 7 August 2017, 5:31 pm EST
I am having an issue with the C1.Silverlight.Excel.C1XLBook (Version 4.0.20113.210 - unfortunately I cannot upgrade to version 5 at this stage due to an in-house library that we are using. This will be migrated to version 5 of the C1 control suite in the next while.)
I am using the C1.Silverlight.Excel.C1XLBook.dll to load a System.IO.Stream. The stream is created from a file that a user selects from an ‘Open File Dialog’ which is restricted to .xls or .xlsx files. When I load a .xlsx file, it works perfectly, however, when trying to load a .xls file I get the following error:
ZipFileException was unhandled by user code - Central dir not found (Images of the errors attached).
Please could someone provide some insight into this for me?
Thank you for all your time and help on this.
Kind regards,
Dave
