Copying a sheet
Posted by: yianeco on 2 November 2019, 2:58 am EST
    Posted 2 November 2019, 2:58 am EST
    Is there a way to copy a sheet from one workbook to another with all formatting (text, colors, borders etc) ?
    Yiannis
  • Posted 4 November 2019, 5:36 am EST
    Hi Yiannis,
    In order to accomplish this, you can save a Spread file from a workbook and then, load it into the desired sheet of another workbook. Please refer the following documentation links for more information on this:
    https://help.grapecity.com/spread/Spread8/WebSiteHelp/webframe.html#savedat3.html
    https://help.grapecity.com/spread/Spread8/WebSiteHelp/add_dat9.html#1020604
    • Excel file Export and Import:
    https://help.grapecity.com/spread/Spread8/WebSiteHelp/saveda24.html
    https://help.grapecity.com/spread/Spread8/WebSiteHelp/add_da20.html
    Pragati
  • Posted 4 November 2019, 5:49 am EST
    Please read again my question carefully!
    I am not talking about excel.
    My question is how to copy one sheet from a spread8 workbook to another spread8 workbook.
    Anyway, how do I load a file (spread8) into a sheet of another workbook ?
    Yiannis
  • Posted 4 November 2019, 7:20 am EST
    Yiannis,
    I got the requirement. You want one sheet (data and formatting) of a workbook to be copied in a sheet of a different workbook. This is why, I suggested two ways.
    You can first save the sheet to a Spread file as follows:
    fpSpread1.SaveToFile "FileName", False
    and, then load the saved file to a sheet of another workbook:
    fpSpread2.LoadFromFile "FileName"
    The another way is to save the file to excel format and then, load the excel file back to a different workbook.
  • Posted 4 November 2019, 12:48 pm EST
    Hi again,
    What you are describing is how to save and open a workbook.
    That was not my request.
    I want to copy a sheet from one workbook to another workbook.
    Can this be done ?
    Yiannis
  • Posted 6 November 2019, 4:38 am EST
    Hi Yiannis.
    I am discussing this with the developers and will get back once there is any information from them.
    Pragati
  • Posted 9 January 2020, 1:30 am EST
    Hi Yiannis,
    As per the developer, you can use the ImportExcelSheet method (or SSImportExcelSheet in the DLL control) to load a specified worksheet from a specified Excel file into the workbook – that is the best way to “copy” the sheet from one workbook into another.
    Pragati
  • Posted 9 January 2020, 1:51 am EST
    As I said before. My question is how to copy a sheet from spread workbook to another spread workbook and NOT how to copy an excel sheet in a spread workbook!
    Yiannis
  • Posted 10 January 2020, 12:54 am EST
    Hi Yiannis,
    I will get back to you on this shortly.
  • Posted 14 January 2020, 2:17 am EST
    Yiannis,
    The methods SaveBlockToBuffer and LoadBlockFromBuffer can be used to copy the contents of a block of cells (which can be the entire sheet):
    https://help.grapecity.com/spread/Spread8/WebSiteHelp/webframe.html#funct316.html
    https://help.grapecity.com/spread/Spread8/WebSiteHelp/webframe.html#funct256.html
    Here, the contents are saved in binary form and the methods are very fast.
