Multiple Checkbox selection
Posted by: aamirzia.charan on 18 May 2019, 1:58 am EST
    Posted 18 May 2019, 1:58 am EST
    We are using farpoint in vb6, we have created a cell with CheckboxCelltype a column is representing dates. Currently a user can check as many boxes as they like, but they need to check one at a time. Does farpoint Spread allow for multiple checkbox selections at one time either by using a key combination or mouse? I’ve looked around and tried various things but no success so far, please help regarding this.
    I know we have to run loop in spread but how it will done ?
    We need records of only true conditions which in spread.
  • Posted 21 May 2019, 7:39 am EST
    Yes, you are right , there is no direct way to handle checkbox click. You need to loop through each checkbox and check it’s value. I have created a sample application to achieve what you are looking for. Please refer to the attachment.
    Deepak Sharma
    InterdependentCheckbox.zip
  • Posted 22 May 2019, 12:53 am EST
    Hello Deepak,
    Thanks for your kind response, your referred sample application is very helpful for me.
    But i have another query regarding selection, if we select multiple checkbox how do I get all selected values. For your reference i have attached sample application.
    Aamir
    multi checkbox.zip
  • Posted 22 May 2019, 5:04 am EST
    Hi Aamir,
    You would need to loop through the rows and check if the checkbox is clicked or not by checking the cell value. Then if the value is true, you can add it to an array and then show this array in the textbox.
    Please refer to the attached sample application.
    Deepak Sharma
    multi checkbox.zip
  • Posted 22 May 2019, 6:49 am EST
    Thanks Dear Deepak,
    attached file is working for me, thanks for your quick response.
    Aamir
