Posted 28 October 2019, 9:32 am EST
Old fonts such as Arial Sams Serif, Courier, etc. work fine with the spread 8. But the new ones like calibri, candara etc, although they can be used in a spread sheet, they dont inherit certains behaviours like “word wraping”.
Look at this example:
“This is the title for column 1”
If using “arial” you can get a word-wrapped text cell as
| This is the title |
|for column 1 |
But if you use calibri you will get
| This is the tit|
|le for column 1|
In the second example, the word : “title” is cut as “tit” and the next line will start with “le”
Is it possible to fix this for Spread8?
Thanks?
