Problem with CliboardCopy/Cliboard Paste and text
Posted by: yianeco on 17 January 2020, 3:39 am EST
  • Posted 17 January 2020, 3:39 am EST
    It seems that when using CliboardCopy to copy text from EDIT cell and then CliboardPaste to paste it an extra quotes character(") is added in the beginning and end of the pasted text.
    Anyone experienced the same ?
    Any workarounds?
    Yiannis
  • Posted 20 January 2020, 6:44 am EST
    Hi Yiannis,
    I could replicate the issue at my end as well. I have forwarded it to the developers (278175) and will let you know once there is any update from them.
    As a workaround, you can retrieve the text once copied using the ClipboardCopy method and then, manually remove the double quotes enclosing the same before the paste method is called.
    Pragati
