Spread.Net trial license is not working
Posted by: sudhanshu-sharma on 15 September 2017, 12:26 pm EST
    Posted 15 September 2017, 12:26 pm EST
    Hello All ,
    we have used spread .NET trial license While running a .NET application.
    While launching the application we face below error:
    Error Message: Exception of type ‘System.Web.HttpUnhandledException’ was thrown. System.Web.HttpUnhandledException (0x80004005): Exception of type ‘System.Web.HttpUnhandledException’ was thrown. —> System.ComponentModel.LicenseException: License for the Spread cannot be found.”
    One more thing, I have gone through the below forumn and observed the below key points that ,
    licenses.licx is present in properties under my project solution but I could not see the App_Licenses.dll in bin folder.
    I donno whether it comes in trial license or not
    Referred post is: http://sphelp.grapecity.com/forums/topic/license-for-the-spread-cannot-be-found/
  • Posted 15 September 2017, 12:26 pm EST
    Do you have License.licx file in your project with appropriate license string? If yes, then on License.licx file in your project, you may right click this license.licx and click on “build run time licenses”, it should create one App_Licenses.dll file in your project and then clean, rebuild and run your application.
    Let me know if this doesn’t help you.
    And if possible please send us a small sample replicating the issue so that we can investigate this issue further.
    Reeva
    In Solution, I could not see any option to do build run time licence
    attached image FYR
    Hello Sudhanshu,
    Yours is a WebApplication or a Website? Because, for licensing Web Site applications, open the Visual Studio Build menu and select Build Runtime Licenses to create the App_Licenses.dll file works.
    Reeva
    Hello Reeva, I could not see this option anywhere please can you guide me how to get Build Runtime Licenses to create this required dll
    Hello Sudhanshu,
    Could you please clarify how long did you have this trial license? Is it still valid or expired?
    Further, I cannot see any Spread License entries in your Licenses.licx file, all entries are for devexpress items.
    However, if you have spread entries in Licenses.licx file then please clarify does the reference in your project have the same version as your Licenses.licx file? Does the licx file have a build action set to “Embedded Resource”?
    Please confirm.
    Reeva
  • Posted 3 April 2018, 5:17 am EST
    Hi ,
    I have generated evaluation license key for Asp.net core project from link https://www.grapecity.com/en/my-account/create-app-key.
    But it is not working in either local machine and deployed server.
    Error message coming in spreadJS Place holder : Invalid License Key. Email us.sales@grapecity.com if you need help.
    I have .net core solution and i need to add this license key to script section for
    Please help here, i need to test performance issue with spread JS in deployed server with evaluation version
