SSB_ALLOWMULTIBLOCKS not working for me to select multiple blocks with mouse
Posted by: gordon.proctor on 25 October 2024, 10:20 am EST
  • Posted 25 October 2024, 10:20 am EST
    I’m using c++ and have an application built over 15 years ago with this spread 8 grid.We have a new requirement to enable multiblock selects. The default of the grid is to not allow this.
    I do the following:
    SSSetBool(m_hWnd, SSB_RETAINSELBLOCK, TRUE);
    SSSetBool(m_hWnd, SSB_ALLOWMULTIBLOCKS , TRUE );
    When I select a single block, both SSGetMultiSelBlocks and SSGetSelectBlock will return the block.
    When I hold down the Ctrl button and mouse select a second block, as soon as I press the left mouse button to select the second block, the first block is no longer highlighted.
    I can not select a second block.
    I thought that maybe we are intercepting the Ctrl key in a PreTranslateMessage and not passing it to the grid. This is not the case as we pass it to the grid. I proved this by trying Ctrl-space, which selects the current column.
    Any help in getting this working would be appreciated.
  • Posted 31 October 2024, 4:32 am EST
    I’ve discovered my problem. We were calling SSSetActiveCell on the Leave cell message, after a left mouse click, which resets the blocks selected.
  • Posted 31 October 2024, 5:15 am EST
    Although I can now see multiple blocks selected in the grid, I only get one block returned in SSGetMultiSelBlocks. Using Spread 8.0.22
  • Posted 31 October 2024, 6:59 am EST
    Correction, I get all blocks except the last block highlighted.
  • Posted 31 October 2024, 9:36 pm EST
    Add debugging statements to track the selection state. For example, log the current selection before and after a mouse click to see if the selection is indeed being cleared. This can help pinpoint where the logic is going awry.
  • Posted 12 December 2024, 10:41 pm EST
    I couldn’t get it to work. How do you fix this? slope
  • Posted 16 December 2024, 10:00 am EST
    I got this working by calling SSGetMultiSelBlocks and storing the blocks. This has all but the last selected. Then I call SSGetSelectBlock and add that. Now I have all selected blocks.
