Upgrading from Spread7.com to Spread8.com
Posted by: bkh_vb on 11 February 2018, 1:47 pm EST
    Posted 11 February 2018, 1:47 pm EST
    Long-time user of Spread7.com and recently downloaded the trial version of Spread8.com. My application is developed in Windows XP Mode under the Windows Virtual PC on a Windows 7 Pro OS. Simple question, do I have to uninstall Spread7.com before installing the trial version of Spread8.com?
  • Posted 12 February 2018, 2:19 am EST
    No, you can install Spread 8 COM on the machine where Spread 7 installed. It should work without conflicting with the older version.
    Deepak Sharma
  • Posted 13 February 2018, 7:39 pm EST
    Next question, the documentation states that Spread8.com will export in Excel 2007 format (.xlxs) but I can’t find in the documentation that it will also import in Excel 2007 format – I am sure that it does, but just want to confirm.
  • Posted 14 February 2018, 5:30 am EST
    Yes, Spread 8 can import an Excel 2007 file too. You can use the ‘OpenExcel2007File’ method to import an excel 2007 file.
    Deepak Sharma
  • Posted 18 February 2018, 1:56 pm EST
    I am testing the trial version of Spread8 and trying to import an .xlsx file with no success.
    Under Spread7, I first tested the file to see if it is a valid Excel file using the following code…
    ExcelTest = Spread1.IsExcelFile(.FileName)
    where .filename is the name of the file captured from a dialog box and ExcelTest is defined as an integer. This code worked.
    However, when I try the test using the following…
    ExcelTest = Spread1.IsExcel2007File(.filename)
    the line compiled and seemed to work but the test failed when the file is definitely an .xlsx file.
    The documentation indicates that the test statement should actually be…
    ExcelTest = Spread1.IsExcel2007File(.filename) as IsExcel2007FileConstants
    but when I add the “as IsExcel2007FileConstants” statement at the end of the line by selecting it from the dropdown box then pressing enter, I receive the following error…
    Compile error: Expected end of statement
    Skipping the Excel test, I tried to open the file using the following statement
    First I saved the name of the .xlsx file in the following variable using
    XLFile = .FileName
    Under Spread7 the code was…
    F = Spread1.ImportExcelBook(XLFile,“”)
    where F is dimensioned as Boolean
    However, under Spread8, the statement I use is
    F = Spread1.OpenExcel2007File(XLFile, “”, -1, “”, “”)
    but when I execute the code I get the following error
    Runtime error 13: Type Mismatch
    even though it had been defined as Boolean
    What am I doing wrong?
  • Posted 19 February 2018, 10:35 am EST
    The code to open an Excel 2007 file is :
    fpSpread1.OpenExcel2007File “C:\Myxls.xlsx”, “”, -1, -1, App.Path & “\ImportExport\log.txt”
    Please test the attached sample application with Spread 8 and let me know if your still face the issue.
    Deepak SharmaSpreadCOM_ImportExport.zip
