About performance
Posted by: belle on 8 September 2017, 8:01 pm EST
    Posted 8 September 2017, 8:01 pm EST
    I have a question about loading data. The table is with 30 columns and 757 rows and it takes more than 1 minutes to done.
    Here is the code:
    Dim ds As DataSet = New DataSet
    ds = cls.GetDataSet(strSQL)
    FpSpread1.Sheets(0).Rows.Count += TableDetail.Tables(0).Rows.Count
    For intRowCount = intPreCount To intPreCount + ds.Tables(0).Rows.Count - 1
          For intColCount = 0 To ds.Tables(0).Columns.Count - 1
                FpSpread1.Sheets(0).Cells(intRowCount, intColCount).Value = ds.Tables(0).Rows(intRowCount - intPreCount).Item(intColCount)
          Next
    Next
    Is any suggesions to speed up? Thanks.
  • Posted 8 September 2017, 8:01 pm EST
    You are getting this delay may because you are assigning values to each cell individually. I suggest you to use the following code snippet to assign value to the spread:
    Dim ds As Data.DataSet = New Data.DataSet()
    Dim da As System.Data.OleDb.OleDbDataAdapter = New System.Data.OleDb.OleDbDataAdapter(sqlStr, conn)
    da.Fill(ds)
    FpSpread1.ActiveSheetView.DataSource = ds
    Ankit Nigam
    It works. Thanks a lot.
    I have some questions.
    First:
    FpSpread1.Columns(0).CellType = New CheckBoxCellType()
    Second:
    The First CellType doesn't work, but the second works.
    1. What's the difference between first and second?
    2. To set Format like FrozenColumnCount, Width, Label, Visible, BackColor, CellType and Formula, which way is better(before or after datasource)?
    3. FpSpread1.ActiveSheetView.Columns(2).Locked = False --> It doesn't work.
        FpSpread1.ActiveSheetView.Rows(2).Locked = False     --> It works.
        How can I set some columns to Locked=false?
    I will answer your question in the order they were asked:
    1) In the first one, default celltype of spread overlaps the CheckBoxCellType(). If you set up the celltype after binding the Spread, then it should work by default, but not if you set the celltype before. You need to set the DataAutoCellTypes property to False to be able to set the CellType property whenever you like.
    2) I suggest you to use all these property after binding.
    3) How you are using the locked property?
    Ankit Nigam
    After binding, it seem locked all cells. I am using locked property below.
    FpSpread1.ActiveSheetView.Columns(0).Locked = False
    And I still have some questions.
    Here is my original code:
    FpSpread1.Sheets(0).Rows.Count = ds.Tables(0).Rows.Count
    For intRowCount = 0 To ds.Tables(0).Rows.Count - 1
                FpSpread1.Sheets(0).Cells(intRowCount, intColCount).Value = xNull(ds.Tables(0).Rows(intRowCount).Item(intColCount))
          Next
          FpSpread1.Sheets(0).Cells(intRowCount, 0).Locked = False
          If xNull(ds.Tables(0).Rows(intRowCount).Item(0)) = "Y" Then
             FpSpread1.Sheets(0).Cells(intRowCount, 0).Value = "1"
          Else
             FpSpread1.Sheets(0).Cells(intRowCount, 0).Value = "0"
          End If
    Next
    To improve performance, modify the code as follow:
    FpSpread1.ActiveSheetView.Columns(0).Locked = False   --->This isn't working.
    How can I check and change value of cells after binding without for-next? Any suggestions?
    Thanks for answering.
    Could you please provide me more information about your requirements?  Do you want to lock all the columns in the spread except the first columns?
    Also you can edit the values in the spread by double clicking the cell.
    Ankit Nigam
    My requirements is to improve performance. I am assigning and checking values to each cell individually. You suggest me code snippet to assign value to the spread. And I find out some questions to use that. After binding, it seem to lock all the columns in the spread and I can't edit the values in the spread by double clicking the cell. How can I unlock columns after binding?
    Another question is how can I assign the checkbox's value dynamically after binding?
    I am not sure why you are getting the locked columns. Could you please open the source(browser’s view source) of the render output and please check if the read-only property set for any column?
    I also suggest you check this forum to know how to set the checkbox’s value dynamically.
    http://www.clubfarpoint.com/Forums/forums/thread/46184.aspx
    Ankit Nigam
    I know why the columns locked. It's my mistake.
    If the value is Y/N, how can I bind to the checkbox value?
    (I know the value 0/1 can set the checkbox's value dynamically.)
    I provide the code snippet to help you more understand my question. Now it takes 50 second to done. Is there anything I can do to imporve performance?
           FpSpread1.Sheets(0).Cells(intRowCount, 0).Value = "1"    'set the checkbox status to True
        Else
           FpSpread1.Sheets(0).Cells(intRowCount, 0).Value = "0"    'set the checkbox status fo False
        End If
    Next
    In this scenario I didn't find any way of improving the performance because the loop will take time depending on the number of rows you have.  However I suggest you to take a look on this forum post in which different methods of performance improvements had been discussed.
    Ankit Nigam
    Ankit is correct that there is not much you can do about peformance if the size of your DataSource is very large. If you are using paging, you could break up this code to only set the rows that are being shown on the page being rendered instead of the entire DataSet, Other than that, you can write your loop more effeciently using For Each instead of a For Loop.
      Dim intRowCount As Integer = 0
      For Each dr As DataRow In ds.Tables(0).Rows
       If Not dr.IsNull(0) Then
        If dr(0).ToString = "Y" Then
         FpSpread1.Sheets(0).Cells(intRowCount, 0).Value = 1   'set the checkbox status to True
        Else
         FpSpread1.Sheets(0).Cells(intRowCount, 0).Value = 0   'set the checkbox status fo False
        End If
       End If
       intRowCount += 1
      Next
    Ankit,
    I have seen that issue before I post this question. Thanks a lot.
    Scott,
    Thanks for answering. I try to compression viewstate, but it's just a little help. I will try to convince the user using paging.
  • Posted 21 November 2017, 3:08 pm EST
    The link in the above comment doesn’t seem to be valid, ankit-nigam. Might you be able to provide the correct link please.
    http://www.clubfarpoint.com/Forums/forums/thread/88706.aspx
