Can't import Excel file
Posted by: a.tholle on 30 March 2020, 8:54 am EST
    Posted 30 March 2020, 8:54 am EST
    I’m trying to get started with the spread component in my ASP.NET MVC 5 application. It can load the component easily using this in my view:
    @Html.FpSpread("FpSpread1")
    However I cannot for the life of me figure out how to import an Excel file to the spread component. I have used the methods from the documentation like so:
    public ActionResult ExcelView2([FarPoint.Mvc.Spread.MvcSpread]FarPoint.Mvc.Spread.FpSpread FpSpread1)
                ViewBag.Message = "Welcome to GrapeCity";
                FpSpread1 = new FarPoint.Mvc.Spread.FpSpread("FpSpread1", new ControllerContext());
                if (FpSpread1 != null)
                    var value = FpSpread1.ActiveSheetView.Cells[0, 0].Value;
                FpSpread1.OpenExcel("PATH/FILENAME.xlsx");
                FarPoint.Web.Spread.DefaultSkins.Office2016White.Apply(FpSpread1);
                FpSpread1.ActiveSheetView.PageSize = FpSpread1.Rows.Count;
                return View(FpSpread1);
    It can open the page view and display an excel-like component, but it does not import the data from the excel file. I’ve tried loading an .xls instead of .xlsx, but it’s the same. I have no idea where to go from here or even if my implementation is correct. The documentation only give methods and no indication of how to use them…
  • Posted 31 March 2020, 7:32 am EST
    To call the ExcelView2 method, we need to make it as Event. Please refer to the attached sample Spread-OpenXLSX.zip and the following code snippet for reference:
    [MvcSpreadEvent("Init", "Spread1")]
            private void ShipmentSpread_Init(object sender, EventArgs e)
                var fpSpread = (FpSpread)sender;
                fpSpread.ActiveSheetView.AllowPage = false;
                fpSpread.Width = Unit.Percentage(100);
                fpSpread.OpenExcel(Server.MapPath("~/Files/FlexGrid.xlsx"));
    Manish Gupta
  • Posted 3 April 2020, 4:12 am EST
    I’ve tried with your sample code, and now it works fine with loading my Excel file. However, it takes a very long time for it to load and it loads without any data, or atleast what I can see. It is so slow, that I cannot get it to change page. Is there a limit to how much data your product can handle?
  • Posted 6 April 2020, 8:34 am EST
    We are not sure why Excel is loading slowly. Please share the excel file with us with the following information:
    • "* “How the file is generated”
    • “The Spread Version you are using”
    • “Browser”
    • “How much time it took to load the file at your end”
    • “OS information”
    Please share the above information so that we may investigate it at our end.
    Manish Gupta
