Displaying a 'busy' dialog during callback
Posted by: philw on 8 September 2017, 7:23 pm EST
    Posted 8 September 2017, 7:23 pm EST
    I was wondering if there is any way to display the Ajax style 'busy' dialog during callbacks. Some of my callbacks take a number of seconds, and it would be good to have a visual indicator to the users that something is happening, especially as the IE  'busy' indicator remains inactive during callbacks.
    I realize that I can place code in the Client events callbackStart and callBackStopped, but am not sure how to proceed from this point.
    Phil
  • Posted 8 September 2017, 7:23 pm EST
    Phil -
    See the following thread...
    http://www.clubfarpoint.com/Forums/forums/post/59037.aspx
    You can do a search on 'async' to see others.
    Wow, as simple as that. Thank you.
     My next question... How do I get to the dialog text, as I will need to localize this?
     Phil
    Phil -
    What dialog text are you referring to?
    I have set 'event.async = true' in the callBackStart event and I am now getting a very useful 'busy' dialog when the callback is in progress that says "Please Wait...". My question is, can I get to this text in order to localize it, as our web application supports multiple languages.
    Phil
    That text is stored in the resx file of the spread.  I do not know of a way to get to it but I will look into it.
    There is not a way to get to the text that is stored in the resource file of the spread.  I will write this up as an enhancement.  For now you would have to create your own DIV to display.
    After some experimenting I found a way to do this...
    Protected Overrides Sub Render(ByVal writer As System.Web.UI.HtmlTextWriter)
    Dim c As Control = FpSpread1.FindControl("waitMsg")
    c.Controls.RemoveAt(0)
    Dim s As String = "Calculating"
    c.Controls.Add(New LiteralControl(s))
    MyBase.Render(writer)
    End Sub
    This will not display the gif, however.  I am still looking into that.
    Here is the completed code to display a different text and the gif...
    Dim imgUrl As String = Me.Page.ClientScript.GetWebResourceUrl(GetType(FarPoint.Web.Spread.FpSpread), "FarPoint.Web.Spread.img.spinner.gif")
    Dim t As String = "<img src='" + imgUrl + "'/>&nbsp;&nbsp;" + s
    c.Controls.Add(New LiteralControl(t))
    End Sub
    Thanks for that Bob, I will give that a try...
    Phil
  • Posted 9 October 2017, 4:40 pm EST
    Hello! I have a very similar issue and I would like to replace the “Please wait” text or remove the control altogether. I am trying to replicate the solution shown above, but it is not working as currently coded. Can anyone assist? We are using: C#, MVC3, Spread 9.4
    	[FarPoint.Mvc.Spread.MvcSpreadEvent("PreRender", "PlanningSht")]
            private void PlanningSht_PreRender(object sender, EventArgs e)
                FpSpread spread = (FpSpread) sender;
                var control = spread.FindControl("waitMsg"); // THIS IS NULL
                //control.Controls.RemoveAt(0);
  • Posted 12 October 2017, 11:17 am EST
    You can handle the PreRender event for the Spread control in your controller and attach a handler for the PreRenderComplete event on the Page:
    private void FpSpread1_PreRender(object sender, EventArgs e)
    FarPoint.Mvc.Spread.FpSpread fpspread1 = (FarPoint.Mvc.Spread.FpSpread)sender;
    System.Web.UI.Page page = fpspread1.Page;
    page.PreRenderComplete += new EventHandler(page_PreRenderComplete);
    Handle the PreRenderComplete event for the page to add your button:
    void page_PreRenderComplete(object sender, EventArgs e)
    System.Web.UI.Page page = (System.Web.UI.Page)sender;
    FarPoint.Mvc.Spread.FpSpread spread = (FarPoint.Mvc.Spread.FpSpread)page.FindControl(“FpSpread1”);
    System.Web.UI.Control c = spread.FindControl(“waitMsg”);
    Please try the code above and let me know if you face any issues.
    Deepak Sharma
  • Posted 16 October 2017, 2:49 pm EST
    Thanks, Deepak! That worked!
  • Posted 17 October 2017, 3:14 am EST
    Glad to to know that!
    Deepak Sharma
