Events not triggered for dynamic buttons placed inside the spread control
Posted by: jonathanlau2828 on 3 April 2019, 2:39 am EST
    Posted 3 April 2019, 2:39 am EST
    We are referring following link for setting a button cell dynamically.
    http://helpcentral.componentone.com/NetHelp/SpreadNet7/ASP2/spweb-setbuttoncell.html
    We could add the button to the cell but the events are not getting triggered. Attached the sample code which is used for our testing.
    test.zip
    Kamal
  • Posted 5 April 2019, 1:44 am EST
    Hi Kamal,
    The issue is because you have added the ButtonCommand EventHandler within the !Page.IsPostBack. Please add handler outside this condition, the issue should be resolved.
    Please refer to the following code snippet for reference.
     protected void Page_Load(object sender, EventArgs e)
                FpSpread1.ButtonCommand += new SpreadCommandEventHandler(this.FpSpread1_ButtonCommand1);
                if (!Page.IsPostBack)
                    FpSpread1.ActiveSheetView.RowCount = 3;
                    FpSpread1.ActiveSheetView.Cells[0, 0].CellType = new FarPoint.Web.Spread.ButtonCellType("OneCommand", FarPoint.Web.Spread.ButtonType.PushButton, "Click");
                    FpSpread1.ActiveSheetView.Cells[1, 1].CellType = new FarPoint.Web.Spread.ButtonCellType("OneCommand", FarPoint.Web.Spread.ButtonType.ImageButton, "images/addtocart.gif");
                    FpSpread1.ActiveSheetView.Cells[2, 2].CellType = new FarPoint.Web.Spread.ButtonCellType("OneCommand", FarPoint.Web.Spread.ButtonType.LinkButton, "www.fpoint.com");
    You may also add event handler from the aspx page instead of CodeBehind.
    Manish Gupta
  • Posted 26 April 2019, 10:01 am EST
    We have a Spread sheet list with multiple rows and each row has one check box in first cell and buttons in 2nd and 3rd cells. We want to the check box event should get fired when the Check box is checked and the button events should fire only button is clicked. Currently, the button event is triggered even when the checkbox is checked and also when the button is clicked. How do we prevent this?
      // checkbox
    fpsStrategyList.CellClick += new SpreadCommandEventHandler(this.fpsStrategyListCellClick);
    // Button
    fpsStrategyList.ButtonCommand += new SpreadCommandEventHandler(this.fpsStrategyListFourmulaViewClick);
          //checkbox Event method
        protected void fpsStrategyListCellClick (object sender, FarPoint.Web.Spread.SpreadCommandEventArgs e)
        int rowindex = Convert.ToInt32(fpsStrategyList.ActiveSheetView.Rows[0].Index);
          //Button Event Method
        protected void fpsStrategyListFourmulaViewClick(object sender, FarPoint.Web.Spread.SpreadCommandEventArgs e)
    Kamal
  • Posted 29 April 2019, 9:46 am EST
    Hi Kamal,
    We are sorry, the CheckBox click can also be handled by using ButtonCommand event. You may add condition check to detect if the event is raised because of the Button or CheckBox.
    However, we have created an enhancement request for the same. We will share the request id soon.
    As you said, each row’s first cell contains CheckBox, you may use the following code snippet:
                FpSpread1.ButtonCommand += FpSpread1_ButtonCommand;
                if (!IsPostBack)
                    CheckBoxCellType cell= new FarPoint.Web.Spread.CheckBoxCellType();
                    cell.AutoPostBack = true;
                    cell.Text = "Some text";
                    FpSpread1.ActiveSheetView.Cells[0, 0].CellType = cell;
            private void FpSpread1_ButtonCommand(object sender, SpreadCommandEventArgs e)
            {  // first column containg checkbox
                if (((System.Drawing.Point)e.CommandArgument).Y == 0)
    			// code for checkbox click
                }else{
                           // code for Button Click
    Hope it helps!
    Manish Gupta
  • Posted 29 April 2019, 11:19 pm EST
    Hi Kamal,
    This request has been forwarded with internal tracking id 272132.
    Manish Gupta
  • Posted 30 April 2019, 4:11 am EST
    Thanks Manish. Your solution helped.
