How to disable delete for certain rows please
Posted by: szilbermints on 12 February 2019, 8:03 pm EST
    Posted 12 February 2019, 8:03 pm EST
    I want to make some rows non editable and non deletable.
    The following forks fine to disable editing for some rows but still allows to delete:
    		  fpSpread1.Sheets(0).Rows(jj).Locked = True
                        fpSpread1.Sheets(0).Rows(jj).CanFocus = False
    Can you please specify if it can be done in server side code and how?
    Thank You
  • Posted 13 February 2019, 3:54 am EST
    Please have a look at client side script code that shows how to disable the delete button for specific rows:-
    <script>
        window.onload = function () {
          $$.j("#FpSpread1").on("ActiveCellChanged", function (e) {
            var event = e.originalEvent;
            var selectedRow = event.Row;
            //alert("Selected row " + selectedRow);
            disableButton(!isAllowDelete(selectedRow));
        var deleteButton = null;
        function disableButton(disabled) {
          if (deleteButton == null) {
            var imgs = $$.j("#FpSpread1 div.commandBar img");
            for (var i = 0; i < imgs.length; i++) {
              var $img = $$.j(imgs.get(i));
              if ($img.attr("onclick").indexOf(".Delete()") != -1) {
                // Disable delete button
                deleteButton = $img;
                break;
          if (deleteButton != null)
            deleteButton.attr("src", disabled ? deleteButton.attr("disabledimg") : deleteButton.attr("enabledimg"));
        function isAllowDelete(row) {
          /// <summary>Indicate whether a row is fine to delete</summary>
          return row != 1;
      </script>
    Please have a look at attached sample as well for the same. Hope it helps.
    Reeva
    WebApplication1.zip
  • Posted 13 February 2019, 10:32 am EST
    Thank You
    Any way to use property or something to do it with Server side code ?
    s
  • Posted 14 February 2019, 3:03 am EST
    Unfortunately, there isn’t any direct server side property to achieve the same.
    We regret the inconvenience.
    Reeva
