Posted 8 September 2017, 5:46 pm EST
Hi
I am trying to set the appearance and behavior of a row based on the value in a column.
I have a grid containing 3 columns.
The 1st column is editable, the 2nd is not editable and the 3rd is hidden.
Now, the value in the 3rd column is a boolean value and when the value in this column is False I want to do the following to the row that cell is in.
1. Change the background color of the row where the value in the 3rd col is false.
2. Lock the 1st column in that row so the user can not edit the data.
3. Show a popup with a message when the user double clicks that row.
Which events should I write the code in and what methods should use to read the value of a cell and set the row style and behavior? Im coding in VB.Net so I would be very grateful if any sample code is in the same.
I am using ver 1.0.8.0 of the grid.
Any help is greatly appreciated
Vikram Karumbaiah
