Posted 9 May 2018, 3:18 am EST
Is the support for Spread 3.0 version still available?
If yes, what is the end date.
Soumya
Forums Home / Spread / Spread for ASP.NET (Web Forms)
Posted by: soumya.dixit on 9 May 2018, 3:18 am EST
Soumya
Posted 9 May 2018, 8:07 am EST
Hi Soumya,
Spread v3.0 is not supported anymore. I would suggest you to upgrade to our latest version of Spread in order to continue getting bug fixes, new features and product support.
Deepak Sharma
Posted 11 May 2018, 12:50 am EST
Hi Deepak,
Thanks for the reply.
Also, could you confirm if Spread v3.0 is compatible with .NET 4.5 framework?
Soumya
Posted 11 May 2018, 5:15 am EST
Hi Soumya,
Spread 3 has never been tested against .NET 4.5 framework. I don’t think it will work on the latest .NET frameworks.
Deepak Sharma
Posted 12 October 2018, 7:33 am EST
Hi Deepak,
Our Web application uses Farpoint spread version 4.0.35 for .Net frame work 3.5.
Now we are planning to upgrade .Net frame work to 4.7.1 version.
Could you please confirm does spread 4.0.35 supports .Net latest version 4.7.1?
Posted 12 October 2018, 10:08 am EST
Hi Lakshmi,
Spread version 4.0.35 would not work with latest .NET Framework. I would suggest you to please upgrade to our latest version i.v. Spread .NET version 11.
Deepak Sharma
Posted 22 October 2018, 5:45 am EST
Thank you Deepak for the confirmation.
Could you please share below details?
1.please let us know upgrade process and cost
2.can we get trail version of spread .net version 11 if so please share dlls or link to download.
Posted 23 October 2018, 3:22 am EST
Hi Lakshmi,
I have forwarded your email to sales team for cost and purchase they will get back to you. You may also contact them at : us.sales@grapecity.com
You can download the trial version of Spread .NET v11.0 from here:
https://www.grapecity.com/en/download/spreadnet
In case you have any questions, please let feel free to get back to me.
Deepak Sharma
Posted 2 January 2019, 10:13 am EST
Hi Deepak,
Does Spread .NET version 11 compactable for .Net frame work to 4.7.2 version also.
Please confirm.
Posted 3 January 2019, 12:47 am EST
Yes, Spread .NET version 11 compatible with .Net frame work to 4.7.2 version as mentioned in documentation link below:-
https://help.grapecity.com/spread/SpreadNet11/WF/webframe.html#product_reqs20.html
Hope it clarifies.
Reeva
Posted 13 February 2019, 10:03 am EST - Updated 30 September 2022, 11:47 am EST
Posted 14 February 2019, 12:14 am EST
You can get the Spread.Net V11 installer from this link:-
https://cdn.grapecity.com/SpreadNET/installer/11.0.20183.0/offlineDownload_ComponentsOnly.zip
However, Spread.Net V12 is also released now which has some new features and bug fixes. You can get the same from this link:-
Hope it helps.
Reeva
Hope it helps.
Reeva
Posted 14 February 2019, 7:37 am EST - Updated 30 September 2022, 11:47 am EST
Posted 15 February 2019, 6:25 am EST
First of all installing Spread using exe from downloaded package I provided above will always install the latest version in online mode( currently V12 is latest version).
Please make sure you are connected to internet while installing in online mode.
However, if you wish to install V11 then please try installing using msi from package you downloaded and it should get installed easily without any error. We have tested the same msi installer directly at our end and it worked well without any error.
Hence, please try the same and share your observations.
Reeva
Posted 15 February 2019, 8:50 am EST
We have followed same steps.But it is getting when tried to install.
as ours is license product,could please give me contact for support in installation.
Posted 18 February 2019, 6:04 am EST
From the screenshots you have sent, it seems you need Spread.Net V12 version. Hence, please download the hotfix installer from this link and follow the steps below:-https://cdn.grapecity.com/SpreadNET/installer/12.0.20181.2/offlineDownload_Full.zip
To install Spread.NET V12 to your computer, please follow these steps:-
Please note you must also read and accept the End User License Agreement terms and conditions to proceed with installing (check box above “Exit” button).
Please try installing Spread V12 using these steps and let us know if it resolves your installation issue.
Reeva
Posted 18 February 2019, 9:35 am EST
thank you fro your response on this.
I have successfully installed EXE which is provided you.
However to activate the product key which is received by your team in email,I could not able to click button after product key entered.(Red cross symbol i could see after product key).
please help me on activate product key
Posted 19 February 2019, 12:56 am EST
could you please clarify that is your is for Spread.Net V11 or V12 as Spread.Net v11 key won’t work with Spread.Net V12 key. Please make sure you are using right keys to activate the product.
And in case you don’t have the correct keys then please contact our sales team at “us.sales@grapecity.com”. They will help you in this regard.
Reeva
Posted 18 April 2019, 11:35 am EST
We have got licensed version of spread 12 and installed in our machine and product key activated which is working fine.
When we try to use the spread dlls and licenses file in another(where spread is not installed) machine,it is saying license not found.
Please help us understood why it is not working.
Posted 23 April 2019, 4:12 am EST
Hi Lakshmi,
The machine should be licensed to run the Spread project successfully. Hence, you should license the other machine too for running the project without any issue. It would be great if you installed spread on the machine to avoid the errors.
Manish Gupta
