Posted 8 September 2017, 5:52 pm EST
I’m trying to get the Spread for Web to work in a SharePoint Web Part. I’ve seen a couple other posts here saying that it should work but I haven’t seen anyone that has succesfully done it. Has anyone actually gotten it to work? If so, could you share what you had to do to make it work? I’ve created a really simple web part (it just displays some text) to make sure there was nothing else wrong with the code and built and deployed it. That worked fine. I then added a reference to the Spread for Web to the project. I rebuilt and deployed and it still worked. Next I just declared the Spread variable and rebuilt the project. When I try to deploy it now it fails in SharePoint and I get the following error message “The “FarPointWebPart” Web Part appears to be causing a problem.”. I’m thinking that there are three DLLs that are with the Spread, do these need to be added to the Manifest.xml file along with the web part DLL for this work? I tried adding them but perhaps I didn’t do it correctly since it still didn’t work.
Any help or ideas would be greatly appreciated.
Thanks in advance,
Rob
