Add List of OwnClass
Posted by: jonigk on 14 January 2020, 9:01 am EST
    Posted 14 January 2020, 9:01 am EST
    HI, we are using spread winforms v12.45.20193.0.
    Currently it´s not possible to add a List of own classes at Sheet.Tag Propery.
    [Serializable]
    public class MyClass
    	// some Properties
    public void Spread_SpreadStart()
    	FarPoint.Win.Spread.SheetView newSheet = new FarPoint.Win.Spread.SheetView();
    	newSheet.Tag = new List<string>(); // working
    	newSheet.Tag = new List<DateTime>(); // working
    	newSheet.Tag = new List<FarPoint.Win.Spread.PrintHeader>(); // working
    	newSheet.Tag = new List<MyClass>(); // not working
    	this.Spread.Sheets.Add(newSheet);
    Error:
    The type System.Collections.Generic.List`1[[SpreadScript+MyClass, 2deaamg3, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]] in assembly FarPoint.Win.Spread, Version=12.45.20193.0, Culture=neutral, PublicKeyToken=327c3516b1b18457 could not be found
    Sven
  • Posted 15 January 2020, 1:57 am EST
    Hi Sven,
    I could not observe any issue when using your given code. Please see the attached sample and make any necessary modifications so we can replicate it at our end and investigate it further.
    SheetTag_CustomClass.zip
    Jitender
  • Posted 21 January 2020, 4:03 am EST
    Hi Jitender,
    thanks for your reply.
    i also could not reproduce the error with your stand alone project. :frowning:
    I attached the stack trace.
    meanwhile we did a workaround an put the List in a new object, which worked fine
    [Serializable]
      public int Number { get; set; }
    [Serializable]
    public class MyClassList
      public List<MyClass>MyList { get; set; }
    //Wird vor dem Erzeugen der Tabellenkalkulation ausgeführt
    	this.Spread.ActiveSheet.Tag = new MyClassList ()
    		MyList = new List<MyClass>()
    System.TypeLoadException: The type System.Collections.Generic.List`1[[SpreadScript+MyClass, or1r4fuf, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null]] in assembly FarPoint.Win.Spread, Version=12.45.20193.0, Culture=neutral, PublicKeyToken=327c3516b1b18457 could not be found.
    bei FarPoint.Win.Spread.Model.SpreadSerializer.OpenXml(FpSpread spread, Stream stream)
    bei FarPoint.Win.Spread.FpSpread.Open(Stream stream)
  • Posted 23 January 2020, 3:14 am EST
    Hi Sven,
    From your stacktrace it seems that you are loading Spread from an XML file. If it’s possible, can you also show us the XML file or a small sample where we can observe this?
    Jitender
  • Posted 27 January 2020, 9:18 am EST
    Hi Jitender,
    i attached the xml file.
    The script is saved in our database and will be loaded / compliled during loading process.
  • Posted 28 January 2020, 2:06 am EST
    It seems the file was not attached.
    Make sure to first archive the XML file to .zip file since only images and zip files can be attached here.
    Jitender
  • Posted 28 January 2020, 5:19 am EST
    Hi Jitender,
    didn’t see the hint yesterday, sorry.
    I have now uploaded it as a zip file
    MyClass-Example.zip
  • Posted 28 January 2020, 6:26 am EST
    Your XML file had no mention of ‘MyClass’. However, I was able to reproduce your scenario.
    Here’s what I did:
    1. Create an instance of FpSpread, add a sheet with its Tag property set to List.
    2. Save this instance to an XML file.
    3. Comment-out the definition of MyClass.
    4. Open the saved XML file with an instance of FpSpread.
    In this case, as the exception says Spread is unable to find the type ‘MyClass’. Maybe, the definition of ‘MyClass’ is not available when you’re opening the XML file?
    But your workaround somehow works so I’m not sure but this error is encountered when the definition of a Type is not available.
    Do you also observe this exception when loading the file in a separate project? If yes, then please create a small sample so we can look into it.
    Jitender
