Adding spanned cells breaking change
Posted by: CKantor on 26 June 2019, 9:14 pm EST
    Posted 26 June 2019, 9:14 pm EST
    I am trying to upgrade Spread for Winforms in my application from version 10 to 12. In the breaking changes under SheetView, it says:
    Adding spanned cells Spread WinForms 12 no longer allows adding spanned cells that have the same anchor cell as the existing span.
    Whenever I try to set ColumnSpan for an anchor cell that has already been set as having a Columnspan, I get a System.ArgumentOutOfRangeException: “Specified argument was out of the range of valid value”. Can you suggest how to set the column span to something different? Can I clear the ColumnSpan before setting it for a cell?
  • Posted 27 June 2019, 5:09 am EST
    The breaking change only refers to the use of AddSpanCell. Using ColumnSpan should work correctly.
    I could not observe this exception with the below code:
    fpSpread1.ActiveSheet.Cells[2, 2].ColumnSpan = 3;
    fpSpread1.ActiveSheet.Cells[2, 2].ColumnSpan = 6;
    Please post a small sample which exhibits the behavior you’re observing.
    Also, mention the exact Spread version so we can check it with that.
    Jitender
  • Posted 27 June 2019, 1:20 pm EST
    I noticed that I was running version 12.45.20181 and the latest version (released on 6/21) is 12.45.20191. After installing the latest version the problem went away.
