Posted 14 December 2019, 1:24 pm EST
Is it possible to bind a BindingSource to a RowHeader.column.DataField?
as in:
FpSpread1_Sheet1.RowHeader.Columns(0).DataField = "Title"
Forums Home / Spread / Spread for WinForms
Posted by: kbj on 14 December 2019, 1:24 pm EST
as in:
Posted 16 December 2019, 6:55 am EST
Spread does not support binding the cells in the row or column header areas.
So you cannot use the Column.DataField property in the row header columns.
If you need to populate cells in the row header area with data from a data source, then you need to iterate over the data source and populate the cells individually using RowHeader.Cells[row,column].Value (or .Text).
