Calculation error when turning on/off AutoCalculation
Posted by: alan.fallas on 23 December 2021, 7:16 pm EST
  • Posted 23 December 2021, 7:16 pm EST
    I have a complex spreadsheet where in order to improve performance of the data loading I’m switching on and off the AutoCalculation property on the SheetView. After setting AutoCalculation=true some formulas don’t get correctly calculated and the result is incorrect. I also tried calling RecalculateAll and the error persists.
    I was able to isolate the problem where I switch AutoCalculation off, assign values to some cells, switch AutoCalculation on and finally get the value from a cell with a formula.
    Can I email the code sample given that my company policies don’t allow me to post in the forum this reduced code sample?
  • Posted 24 December 2021, 3:09 am EST
    Hi Alan,
    We have created a support case [ID: CAS-27746-H5Y4Q9] for you on our Support Portal which is private. You can share your sample there.
    You will find the case in the “My Support” section of your Grapecity account.
    Avnish
