Posted 20 February 2023, 6:01 pm EST
I have a simple sheet, displaying data in columns. I am trying to have the sheet automatically size each column to fit its content using the GetPreferredWidth method, but it is not using the column header text to determine the ideal width, even though the documentation says that it should. Here is my code for sizing the columns:
Public Sub Post_Setup_Spread_Formatting(Sprd As FarPoint.Win.Spread.FpSpread)
With Sprd.ActiveSheet ' Size columns For c As Integer = 0 To .Columns.Count - 1 Dim sz As Single = .Columns(c).GetPreferredWidth .Columns(c).Width = sz Next End With End Sub
I have disabled WordWrap for all of the column headers as follows (also in documentation):
Dim ch As New FarPoint.Win.Spread.CellType.EnhancedColumnHeaderRenderer ch.WordWrap = False fpFeeds.ActiveSheet.ColumnHeader.DefaultStyle.Renderer = ch
I have also tried using the GetPreferredColumnWidth method of the sheet, setting the ignoreheaders parameter to False, but that doesn’t do anything. In fact, for any given column the values returned by:
fpFeeds.Sheets(0).Columns(x).GetPreferredWidth, fpFeeds.Sheets(0).GetPreferredColumnWidth(x, True), and fpFeeds.Sheets(0).GetPreferredColumnWidth(x, False)
are all the same.
One thing I noticed is that setting the Font of the spread did not change the fonts of the columns or of the column headers, so I manually changed those before trying to size the columns, but that did not fix things.
So I am at my wits end with this. What can I do? Thank you.
Vijay
