Carriage Return within a Cell -> Save to Excel
Posted by: craigreillyvideowestinc-com on 8 September 2017, 3:23 pm EST
    Posted 8 September 2017, 3:23 pm EST
    A have tried several variables.
    Example Cell Text:
    Text & vbCrLf & Text
    Text & Chr(10) & Text
    etc…
    On Spread- they show fine.
    When I save to Excel and open in Excel (XLS or XLSX) the text appears in 1 line on the cell. But the formula bar shows it as 2 lines.
    Doubleclicking the cell and tapping enter key, in Excel, then causes the Line Break to appear properly.
    Is this a result of Spread or a bug in Excel?
  • Posted 8 September 2017, 3:23 pm EST
    You need to set the CellType’s wordwrap and Multiline property to true before exporting it to excel and then it will work correctly.
    [vb]Dim g As New FarPoint.Win.Spread.CellType.TextCellType()
    g.WordWrap = True
    g.Multiline = True
    Me.fpSpread1.AllowEditOverflow = True
    Me.fpSpread1.ActiveSheet.Columns(5).CellType = g
    fpSpread1_Sheet1.Cells(5, 5).Text = “test” + Environment.NewLine + “EmptyString”[/vb]
    Hope it helps.
    Reeva
    interesting. will give it a shot.
    Please take your time to check the solution and revert back at your convenience.
    Reeva
    worked perfect. thank you so much.
    We are glad to know that your issue has been resolved.
    Reeva
  • Posted 2 December 2017, 7:35 pm EST
    Is there a way to do the same in js? im having the same issue in wijmo 5.20173.380, in a merged cell im trying to put some break lines but after exporting to excel “the text appears in 1 line on the cell. But the formula bar shows it as 2 lines.
    Doubleclicking the cell and tapping enter key, in Excel, then causes the Line Break to appear properly.”
