Checkbox on 300 dpi
Posted by: tosch on 18 February 2020, 8:50 am EST
    Posted 18 February 2020, 8:50 am EST - Updated 30 September 2022, 1:35 pm EST
    On a screen with 300dpi the checkbox looks really bad.
    Is there a way to get a better quality image in a checkbox celltype?
    Thomas
  • Posted 20 February 2020, 6:53 am EST
    I don’t see the problem with Spread.Net13 in a 300 DPI environment. What is the spread version that you are using?
    Can you try to test your application with Spread.Net10 v3/+ with .Net F/w > 4.7 ?
    Also, see if the following helps:
    Add the following line to the app’s config file:
    Ruchir
  • Posted 20 February 2020, 7:01 am EST
    sorry forgot to mention that we are still using 11.45.20183.0.
    Is the appsettings key also supported in V11.45?
    Thomas
  • Posted 24 February 2020, 7:22 am EST
    As you are using Spreadv11, you should not face the issue. If you create a simple application (drag drop FpSpread onto form, bind it to include a CheckBox field) then executing it over a high DPI environment, do you still face the issue? If not, could you share a stripped down version of your application.
    Ruchir
  • Posted 24 February 2020, 8:03 am EST
    Here is a little sample app and a screenshot on how it looks on 300dpi.
    Thomas
    SpreadCheckbox.zip[img]https://gccontent.blob.core.windows.net/forum-uploads/file-0c141476-58ac-41e2-8db4-f68248537ef0.jpg[/img]
  • Posted 24 February 2020, 8:05 am EST
    you have to download the screenshot to see that the checkbox looks funny.
    Thomas
  • Posted 25 February 2020, 10:21 am EST - Updated 30 September 2022, 1:35 pm EST
    Hello Thomas,
    Unfortunately, I still could not replicate the issue. See attached image.
    I executed your application over Win7 having 300+ DPI and using Spread 11.45.20183.0.
    Were you/anyone else able to observe this issue over any other environment? To continue further, we need to first replicate the issue in order to assist you effectively.
    Ruchir
  • Posted 25 February 2020, 10:29 am EST
    Did you run the sample on Win10?
    Thomas
  • Posted 26 February 2020, 11:04 am EST
    Thomas,
    Yes, I checked the issue over Windows10 and the checkbox looks proper.
    Ruchir
