Convert cells with a formula to a value
Posted by: niels on 22 May 2023, 7:54 am EST
    Posted 22 May 2023, 7:54 am EST
    Version 16.1
    The workbook contans some Custom Function
    This can be done
    FpSpread.SaveExcel(fileName, ExcelSaveFlags.UseOOXMLFormat | ExcelSaveFlags.NoFormulas);
    But Is it possible to do this only it a formula contains a specific Custom Function?
  • Posted 22 May 2023, 7:59 am EST
    This seems to work
    cell.Copy(cell, ManipulationOptions.All ^ ManipulationOptions.Formulas);
    But not for dynamic arrays
  • Posted 22 May 2023, 8:03 am EST - Updated 22 May 2023, 8:08 am EST
    O no this seems not to work for dynamic arrays
  • Posted 22 May 2023, 9:18 am EST
    This works
    var cell = worksheet.Cells[r, c];
    var formula = cell.Formula;
                            if (formula != null && formula.Contains("MH."))
                                var ctx = FpSpread.AsWorkbook().WorkbookSet.CalculationEngine.EvaluationContext;
                                var value = FpSpread.AsWorkbook().WorkbookSet.CalculationEngine.Evaluate(formula, worksheet,
                                    new CellReference(cell.Row, cell.Column));
                                var columnCount = value.GetColumnCount(ctx);
                                if (columnCount < 0) continue;
                                var rowCount = value.GetRowCount(ctx);
                                if (rowCount < 0) continue;
                                var range = worksheet.Cells[cell.Row, cell.Column, cell.Row + rowCount - 1, cell.Column + columnCount - 1];
                                range.Copy(range, ManipulationOptions.Values | ManipulationOptions.Comments | ManipulationOptions.ConditionalFormatting | ManipulationOptions.Formats | ManipulationOptions.Formatting | ManipulationOptions.NumberFormats);
  • Posted 24 May 2023, 1:34 am EST - Updated 24 May 2023, 2:33 am EST
    Hi Niels,
    Unfortunately, we could not replicate the issue on end by using the given information. We have attached a sample application for your reference. See FormulaToValueCells.zip
    We kindly request you update the attached application so that we can reproduce the issue on our end. Otherwise, please provide a stripped-down version of the sample application that replicates the issue on your end.
    Thanks & Regards,
    Aastha
