Posted 15 January 2019, 7:38 am EST
By default, CellTags are preserved on copy paste of cells ie wheever you set a cell tag and copy that cell and paste to another cell and then if yyou get the tag of the pasted cell then it is same as that of copied cell’s tag.
Hence, please try running attached sample wehreinwe have set cell tag to Cell[0,0] and select Cell[0,0] and press Ctrl+C and then select Cell[0,2] and press Ctrl+V and now if you try to get the tag of Cell[0,2] then it is same as Cell[0,0].
Hope it helps. Let us know if your requirement is something else
Reeva
WindowsFormsApp1.zip
