Copy/Paste with differnt amount of columns
Posted by: tosch on 23 October 2018, 4:23 am EST
  • Posted 23 October 2018, 4:23 am EST
    When I copy rows from a sheet with any number of columns and paste them into a sheet with less columns, no data is pasted.
    This is happening in V11 and used to work fine in V7.
    Thomas
  • Posted 24 October 2018, 4:22 am EST
    I am unable to reproduce the issue with the latest build of SpreadWinform. Please refers to the attached video. Could you please check with the latest build. You can download the latest build from the following link:
    https://www.grapecity.com/en/download/spreadnet
    Hope it helps.
    vid_SpreadCopy.zip
  • Posted 24 October 2018, 4:45 am EST
    This is how a tested this issue:
    put Spread1 on a form with 3 columns
    put Spread2 on a form with 2 columns
    put Spread3 on a form with 4 columns
    Now enter some data in all columns in Spread1, select the whole row and copy using Ctrl-C.
    Now select Spread2, click in a cell on column A and hit Ctrl-V → no data is pasted
    Select Spread3, click in a cell in column A and hit Ctrl-V → All the data is pasted correctly
    Tested with version 11.45.20183.0
    Hope this helps to reproduce the problem.
    Thomas
  • Posted 25 October 2018, 4:57 am EST
    Thanks for the details steps.
    I have escalated the issue to our development team(266321) and will inform you once I get any reply from them.
