Posted 9 January 2023, 8:29 pm EST
What is the process for creating a distribution license for Spread 16?
We also need a distribution license for WinForms Edition components, but that does not change the Spread 16 process, correct?
Forums Home / Spread / Spread for WinForms
Posted by: pauld on 9 January 2023, 8:29 pm EST
Posted 10 January 2023, 1:46 am EST
Hi Paul,
A separate distribution license key is not required for the Spread 16 WinForms. The license key/serial key you are provided with at the time of purchase is the only key you will need to activate on your development machine.
The Spread 16 WinForms follow a similar licensing model to the C1 WinForms Edition controls, as we explained in your other case (https://www.grapecity.com/forums/winforms-edition/create-distribution-license-for-winforms-edition).
Below is the documentation link showing how you can activate your license key.
(https://www.grapecity.com/spreadnet/docs/latest/online-win/spwin-activate.html)
Below is the documentation link showing how you can create the license file to be embedded in your WinForms application that uses Spread 16.
(https://www.grapecity.com/spreadnet/docs/latest/online-win/spwin-createruntimelicense.html)
After the application is built with a correct license file embedded, it can be further distributed to your users.
Thanks, and Kind Regards,
