Posted 25 June 2018, 4:03 am EST
Hi there,
I want to display the data in multiple rows.
When the user put the mouse over a cell i want a custom text for each cell in the spread.
Is that possible?
How?
Many thanks
Forums Home / Spread / Spread for WinForms
Posted by: XOtano on 25 June 2018, 4:03 am EST
Hi there,
Is that possible?
How?
Many thanks
Posted 27 June 2018, 7:04 am EST
If you want to show the custom text( your own data, not the default data in the cell) as a text tip on hovering cells on the Spread, then you need to set the TipText property in the TextTipFetch event of Spread as given below:-
private void Form1_Load(object sender, EventArgs e)
fpSpread1.ActiveSheet.SetValue(0, 0, "Cell[0,0]");
fpSpread1.ActiveSheet.SetValue(0, 1, "Cell[0,1]");
fpSpread1.ActiveSheet.SetValue(0, 2, "Cell[0,2]");
fpSpread1.TextTipPolicy = FarPoint.Win.Spread.TextTipPolicy.Floating;
fpSpread1.TextTipDelay = 1000;
fpSpread1.TextTipFetch += fpSpread1_TextTipFetch;
void fpSpread1_TextTipFetch(object sender, FarPoint.Win.Spread.TextTipFetchEventArgs e)
if (e.Column == 0 && e.Row == 0)
e.TipText = "New Text Tip on Cell[0,0] on hovering mouse";
if (e.Column == 1 && e.Row == 0)
e.TipText = "New Text Tip on Cell[0,1] on hovering mouse";
e.ShowTip = true;
Hope it helps.
Reeva
