Drag and Drop in Heirarchical
Posted by: patrik on 4 February 2018, 2:49 pm EST
    Posted 4 February 2018, 2:49 pm EST
    Hi
    I try to use drag and drop in Heirarchical.
    I only success to do in the first level, but in e.sheetview I not success.
    See my code, is it possible to do?
    drag_and_drop.zip
  • Posted 6 February 2018, 5:05 am EST
    You can handle the ChildWorkbookCreated event and set the AllowDragDrop AllowRowMove property there. For example:
     Private Sub FpSpread1_ChildWorkbookCreated(sender As Object, e As FarPoint.Win.Spread.ChildWorkbookCreatedEventArgs) Handles FpSpread1.ChildWorkbookCreated
            e.Workbook.AllowRowMove = True
            e.Workbook.AllowDragDrop = True
        End Sub
    I hope it helps.
    Deepak Sharma
  • Posted 6 February 2018, 2:19 pm EST
    I have added this in my project, but I don’t understand where I get the event if I hold my mouse over the row and where I get information that the drop have been made.
  • Posted 7 February 2018, 10:49 am EST
    Hi Patrik,
    Dragging row/column/selection from one Spread to another is not an inbuilt feature. You can handle the MouseDown/Mouse Up events to know when drag started and stopped. You can refer to the demo sample:
    C:\Program Files (x86)\GrapeCity\Spread.NET 11\Windows Forms\v11.40.20177.0\Samples\Cs\SpreadWinDemo\Features\DragDrop.cs
    Deepak Sharma
  • Posted 7 February 2018, 5:54 pm EST
    I have use this sample in my code I uploaded, my questions was in next level in Heirarchical
    e.SheetView…
  • Posted 12 February 2018, 7:02 am EST
    This is something I can’t do or?
  • Posted 13 February 2018, 10:05 am EST
    Hi Patrik,
    Since drag and drop from outside Spread is not a built in feature I did not find an easy way to implement it for chidview. It would require mouseup/mousedown/dragover/dragdrop events handled for both parent views and childviews.
    Deepak Sharma
  • Posted 6 August 2020, 4:52 am EST
    I still havent success with this.
    How do I access to parent and childview, with code below I guess I not access in a proper way.
    Private Sub FpSpread2_DragOver(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles FpSpread2.DragOver
        Dim p As Point = FpSpread2.PointToClient(New Point(e.X, e.Y))
        Dim range As FarPoint.Win.Spread.Model.CellRange = FpSpread2.GetCellFromPixel(0, 0, p.X, p.Y)
        If range.ColumnCount = -1 And range.RowCount = -1 Then
            Return
        End If
        Dim sel As FarPoint.Win.Spread.Model.CellRange = FpSpread2.ActiveSheet.GetSelection(0)
        If Not (sel Is Nothing) Then
            FpSpread2.ActiveSheet.RemoveSelection(sel.Row, 0, 1, 7)
        End If
        iRow = range.Row
        FpSpread2.ActiveSheet.AddSelection(range.Row, 0, 1, 7)
    End Sub
  • Posted 11 August 2020, 3:28 pm EST
    Can you kindly share the current cod you have? It will help us investigate accordingly.
  • Posted 15 August 2020, 3:15 am EST
    Here is a sample, it’s working perfect to drop to level 1 but not to level 2DragAndDrop.zip
  • Posted 17 August 2020, 2:54 pm EST
    Thank You, Patrik.
    I have forwarded it to the team for further investigation [ID: 10924] and will get back to you as soon as there is any solution/information.
  • Posted 18 August 2020, 12:48 pm EST
    Thanks alot. it’s differcult to have the user to remeber only drop in level 1.
  • Posted 21 August 2020, 2:43 am EST
    I am sorry to inform that the developers have confirmed that Spread does not support drag from parent spread (level 1) to child spread (level 2) and vice-versa. This is internal logic of spread, so it has no workaround.
    ~Regards,
