Dubble click on a row
Posted by: patrik on 25 August 2019, 5:18 am EST
  • Posted 25 August 2019, 5:18 am EST
    I got this error with Spread SP2
    my code:
     Private Sub FpSpread1_CellDoubleClick(sender As Object, e As FarPoint.Win.Spread.CellClickEventArgs) Handles FpSpread1.CellDoubleClick
            Login()
            e.Cancel = True
        End Sub
    System.Exception
    HResult=0x80131500
    Message=Exception handled in FpSpread.WndProc
    Source=FarPoint.Win.Spread
    StackTrace:
    at FarPoint.Win.Spread.FpSpread.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
    at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
    at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.RunDialog(Form form)
    at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
    at System.Windows.Forms.Form.ShowDialog()
    at Cadbim.Huvudmeny.Huvudmeny_Load(Object sender, EventArgs e) in C:\Users\Patrik\OneDrive - Cadbim Solutions AB\Patrik\Projects\Cadmim Kalk\Cadbim Kalkyl\Huvudmeny.vb:line 54
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    Inner Exception 1:
    NullReferenceException: Objektreferensen har inte angetts till en instans av ett objekt.
  • Posted 26 August 2019, 1:51 am EST
    I am unable to reproduce the issue at my end. Please refer to the attached application.
    If the problem still occurs them, Could you please either modify the attached application or provide your own stripped-down project so that I can try reproducing the same behavior at my end and assist you further accordingly?
    Spread_DoubleCLick.zip
  • Posted 26 August 2019, 10:19 am EST
    Here is a update that make this error.Spread_DoubleCLick.zip
  • Posted 27 August 2019, 6:34 am EST
    Hello Ramakrishna,
    Thanks for the sample.
    I am able to reproduce the issue in the same environment. Hence, I have escalated the issue to our development team(275265) and will inform you once I get any information from them.
  • Posted 28 August 2019, 5:51 am EST
    Hello Mohitg
    Thanks for your answer.
    I think I should rollback to SP1.
    you know where to find?
    /Patrik
  • Posted 28 August 2019, 5:53 am EST
    I also want to inform that Spread Designer in version 12 are not working good when you do something with header. I found many bugs there.
  • Posted 29 August 2019, 2:49 pm EST
    Please tell me where to find Spread with SP1,
    I can’t working with my project for the moment.
  • Posted 29 August 2019, 11:58 pm EST
    Sorry for the delay!
    You can download the SP1 installer from the following link:
    https://cdn.grapecity.com/SpreadNET/installer/12.0.20191.0/offlineDownload_Full.zip
    Could you please share the bugs that you have found so that we can fix them at our end.
    This is will be very helpful for us.
