Posted 24 August 2018, 3:25 pm EST
In changing from Spread.NET 10 to Spread.NET 11, we found some of our code broke with respect to pasting. If I select a row (by clicking on the row header) or any other range of cells, copy, and then paste, it works just fine. The exception is if one of the target cells- where the content should be pasted- is locked, in which case NONE of the copied values are pasted.
This worked before we migrated to 11. Is there anything I can check or change to fix this?
