Error trying to open excel file
Posted by: ljk on 21 June 2023, 9:44 am EST
    Posted 21 June 2023, 9:44 am EST
    I am opening SDJAB2024FORM.xlsx and saving it as SDJAB2024FORM_Copy.xlsx. When trying to open then SDJAB2024FORM_Copy.xlsx, a popup says “We found a problem with some content in ‘SDJAB2024FORM_Copy.xlsx’. Do you want us to try to recover as much as we can?” Chose Yes. Then get the message “Repaired Records: View from /xl/worksheet/sheet4.xml part”
    This is what the log file says:
    error198720_01.xml
    Errors were detected in file ‘C:\TFS\Trunk\Code\SAS\bin\Debug\SDJAB2024FORM_Copy.xlsx’Repaired Records: View from /xl/worksheets/sheet4.xml part
    This is the code I am using to open and save the excel file.
    Dim spr As New FarPoint.Win.Spread.FpSpread
    spr.OpenExcel(“C:\TFS\Trunk\Code\SAS\bin\Debug\SDJAB2024FORM.xlsx”)
    spr.SaveExcel(“C:\TFS\Trunk\Code\SAS\bin\Debug\SDJAB2024FORM_Copy.xlsx”, FarPoint.Excel.ExcelSaveFlags.UseOOXMLFormat Or FarPoint.Excel.ExcelSaveFlags.DocumentCaching)
    How can I resave this file without getting the error?SDJAB2024FORM.zip
  • Posted 22 June 2023, 4:47 am EST
    It seems like you have created a duplicate case.
    We have responded here: https://www.grapecity.com/my-account/my-support/case/4b9b8b85-3910-ee11-8f6d-000d3a574715.
    Now we will continue with the above.
    regards,
    Nitin
