F2 F3 F4 how to prevent spread overtook these function keys
Posted by: wwu-sec on 8 September 2017, 12:37 pm EST
  • Posted 8 September 2017, 12:37 pm EST
    in my harsh project, F2 F3 F4 already defined in outside container, but when spread cell get focus, these function keys are routed to spread specific function, i don’t need that, please teach me, it is very busy project, thanks a lot!!
    You would need to cancel the action of the keys in the InputMap of Spread.
    		Dim im As FarPoint.Win.Spread.InputMap
    im = FpSpread1.GetInputMap(Spread.InputMapMode.WhenAncestorOfFocused)
    im.Put(New FarPoint.Win.Spread.Keystroke(Keys.F2, Keys.None), FarPoint.Win.Spread.SpreadActions.None)
    Dear BobM,
    my F2 handler is a customized function, that will be fine? i mean when hit F2 in spread cell, it should invoke that customized F2 handler.
    thanks a lot.
    What is it you want to happen when you hit the F2 key?
        'disable Function key in farpoint spread, because function key already defined in FORM
    im = grid_upper.GetInputMap(FarPoint.Win.Spread.InputMapMode.WhenAncestorOfFocused)
    im.Put(New FarPoint.Win.Spread.Keystroke(Keys.F4, Keys.None), FarPoint.Win.Spread.SpreadActions.None)
    im = grid_bottom.GetInputMap(FarPoint.Win.Spread.InputMapMode.WhenAncestorOfFocused)
    it works! thanks a lot!!!
  • Posted 17 August 2021, 10:21 pm EST
    I have a problem when applying your direction in my code. Please tell me what are ‘grid_upper’ and ‘grid_bottom’?
  • Posted 17 August 2021, 11:15 pm EST
    I found it. It is the spread that I want to enable the key F2, F3, F4.
    We set these code in loading form. It works well.
    Thank you very much. It helped me more.
