Font size change before and after decimal
Posted by: sanket.joshi on 20 September 2021, 5:10 am EST
  • Posted 20 September 2021, 5:10 am EST
    We have a requirement in project where the user wants configuration to change the font size and style in the price field column before and after decimal point. We are using grapecity winform spread version 12 which we are using. Can you help us how to provide solution to the requirement
    example; they want like this
    112233.5555
    112233 - different font
    5555 - different font
    both values are part of price field so in one column of spread sheet
    Sanket
  • Posted 21 September 2021, 2:43 am EST
    You can consider using RichTextCellType for this. Although this would require you to modify the actual values.
    Please check following documentation to see if this is appropriate for your requirements:
    https://help.grapecity.com/spread/SpreadNet12/WF/webframe.html#spwin-setrichtextcell.html
    If you don’t want to modify the cell value itself, then you can create a custom cell type that handles the cell rendering according to your requirements.
    You can refer the attached sample to see how this can be done.
    CustomNumericCell.zip
    Jitender
