Formulas are translated according to Region format
Posted by: petri.rasanen on 7 June 2019, 4:30 am EST
    Posted 7 June 2019, 4:30 am EST
    I updated Spread.NET 12 to SP1. Now the formulas are translated according to Region format. This happens also in Spread Designer. You can test this changing the region format setting to Finnish (Finland). Is there anyway to prevent this, some property maybe?
    Br,
    Petri
  • Posted 11 June 2019, 6:44 am EST
    Hello Petri,
    Could you please share a screenshot of the issue? Also, what is your system culture set to?
    Ruchir
  • Posted 11 June 2019, 8:18 am EST - Updated 30 September 2022, 1:50 pm EST
    Screenshot is from Spread Designer (also happens in spread component).
    Br,
    Petri
  • Posted 13 June 2019, 9:21 am EST
    Thank you Petri.
    This behavior seems to be consistent with the behavior mentioned in Spread12 documentation. For reference, please refer following documentation page:
    https://help.grapecity.com/spread/SpreadNet12/WF/webframe.html#spwin-useregional.html
    Ruchr
  • Posted 14 June 2019, 4:21 am EST
    This will be an issue on our tests that checks formulas are correct, because this now depends on region format. Hope there will be some kind of property for these translations in future version.
    Br,
    Petri
  • Posted 17 June 2019, 8:17 am EST
    We’re discussing this with the developers [Internal Tracking ID: 273360].
    I’ll update this thread once we have more information.
    Jitender
  • Posted 20 June 2019, 6:59 am EST
    Hi Petri,
    You can explicitly specify a Language using this code:
    fpSpread1.AsWorkbook().WorkbookSet.LanguagePackage = GrapeCity.Spreadsheet.Localization.LanguagePackage.English;
    Note that you will need to specify this before setting any formulas in cells.
    Also, if you’re loading your data from an excel file, you would need to specify the Language pack again (this would be fixed in future so that Spread remembers the previously set Language when opening an Excel file).
    Jitender
