GetPreferredRowHeight issue
Posted by: don on 2 January 2019, 9:03 am EST
    Posted 2 January 2019, 9:03 am EST
    In the new version of spread (v12), the GetPreferredRowHeight will not return (hang) in the following condition. I have found a workaround, but can you look into this.
    1. Set a formula for the whole column, like the following.
      fpSpread1.Sheets(0).Columns(_colIndexTotalAppraisalCalc).Formula = “RC5 * RC6”
    2. Get the row height using the following.
      fpSpread1.Sheets(0).GetPreferredRowHeight(1)
    If you execute this more than once, spread hangs.
    If you set the formula using Cells, it works fine. like this.
    fpSpread1.Sheets(0).Cells(0, _colIndexTotalAppraisalCalc, totalRows - 1, _colIndexTotalAppraisalCalc).Formula = “RC5 * RC6”
    Turning Legacy to All or any other combination does not seem to help.
  • Posted 3 January 2019, 12:04 am EST
    I used your given code but I couldn’t observe any unresponsive behavior. Can you please modify the attached sample so we can further investigate it?
    Jitender
    PreferredRowHeight.zip
