Posted 2 January 2020, 3:55 am EST
I have a questions , when I set fpspread1.activesheet.protect = tue
the columnheader is hard to read , it turns to disable style . It will becomes hard to read. how to return to it’s normal state .
thanks.
Forums Home / Spread / Spread for WinForms
Posted by: hibwja on 2 January 2020, 3:55 am EST
thanks.
Posted 2 January 2020, 4:27 am EST
I understand. To resolve this, I suggest you to please find my reply towards the same question asked by another customer: https://www.grapecity.com/forums/spread-winforms/protected-sheet-skin#hi-markto-change-the-forec
Should you need anything in addition to it, feel free to let me know.
Best wishes,
Ruchir
Posted 2 January 2020, 11:47 am EST
I found this post before I asked. and download the zip for , but the columnheader still in disabled mode.
I had been use farpoint spread version 5 . I don’t need to set fpspread to protect mode and I can set columns to be in disable mode. but in version 12 ,I have to set protect property to be true . so I can set columns locked.
In my situation is I need to lock some columns , and unlock others column. and do not change my columnheader color. what should I do ? thanks.
Posted 2 January 2020, 1:00 pm EST
I found one property is missing, it works , set the legacyBehaviors to be style. and it workd like version 5. thanks.
Posted 3 January 2020, 12:35 am EST
We are glad that you were able to find the missing property to follow the suggestion.
~Ruchir
