How to display two diferentes datasources on fpspread in the screen
Posted by: jbingenieriasoftware1921 on 19 October 2019, 12:47 am EST
  • Posted 19 October 2019, 12:47 am EST
    i HAVE THIS CODE WORKS FINE
    globalDA = new OleDbDataAdapter();
    globalDA.SelectCommand = oCommand;
    DataSet dsGlobal = new DataSet(“rtpGlobal”);
                globalDA.Fill(dsGlobal);
                fpSpread1.DataSource = dsGlobal; //ALM01
    BUT I NEED TO SHOW ANOTHER ONE
  • Posted 21 October 2019, 1:10 am EST
    Sorry to mention that there is no way to bind Spread with multiple datasource.
  • Posted 30 October 2019, 12:54 pm EST
    but I need to fill sheet area maybe with TableView I can do it
    but I need convert dataset on object[,]
  • Posted 30 October 2019, 8:07 pm EST
    iT IS MY CODE
    BUT ON THIS LINE
    sheet.Cells[iRow2, col].Value = dataB[row2 - 4, col - 1];
    SAY ME System.IndexOutOfRangeException
    I need one table at top and another below
          private void SetSheetData(SheetView sheet)
                oCommand = new OleDbCommand("[dbo].[sp_CortesxTurno]", dbConn);
                oCommand.CommandType = CommandType.StoredProcedure;
                OleDbParameter oDate1 = oCommand.Parameters.Add("@date1", OleDbType.VarChar);
                OleDbParameter oDate2 = oCommand.Parameters.Add("@date2", OleDbType.VarChar);
                OleDbParameter sParam1 = oCommand.Parameters.Add("@sParam1", OleDbType.VarChar);
                OleDbParameter sParam2 = oCommand.Parameters.Add("@sParam2", OleDbType.VarChar);
                OleDbParameter sParam3 = oCommand.Parameters.Add("@sParam3", OleDbType.VarChar);
                //OleDbParameter nUsuario = oCommand.Parameters.Add("@pUsuario_Id", OleDbType.VarChar);  // usuario
                oDate1.Direction = ParameterDirection.Input;
                oDate2.Direction = ParameterDirection.Input;
                sParam1.Direction = ParameterDirection.Input;
                sParam2.Direction = ParameterDirection.Input;
                sParam3.Direction = ParameterDirection.Input;
                //nUsuario.Direction = ParameterDirection.Input;
                oDate1.Value = dateTimePicker1.Text.Replace(" p.m.", "");
                oDate2.Value = dateTimePicker2.Text.Replace(" p.m.", "");
                sParam3.Value = "";
                sParam1.Value = "";
                sParam2.Value = "3";
                turnosDA = new OleDbDataAdapter();
                turnosDA.SelectCommand = oCommand;
                DataSet dsTurnos = new DataSet("rtpTurnos");
                turnosDA.Fill(dsTurnos);
                var rowsTurnos = dsTurnos.Tables[0].Rows.Count;
                //List<CortesxTurnos> lsCTurnos = new List<CortesxTurnos>();
                object[,] data = new object[rowsTurnos, 7];
                int x = 0;
                try
                    foreach (DataRow row in dsTurnos.Tables[0].Rows)
                        for (var c = 0; c < 7; c++)
                            data[x, c] = row.ItemArray[c];
                        x++;
                catch (Exception ex)
                { var _ = ex.Message; }
                //object[,] data =  { { "STATUS", "OPERATING", "BUDGET", "ACTUAL", "DIFFERENCE ($)", "DIFFERENCE (%)" },
                //    { 0, "Advertising", 600, 545, 0, 0 },
                //    { 0, "Debts", 125, 150, 0, 0 },
                //    { 0, "Benefits", 100, 100, 0, 0 },
                //    { 0, "Supplies", 100, 90, 0, 0 },
                //    { 0, "Postage", 150, 145, 0, 0 },
                //    { 0, "Rent or mortgage", 1000, 1000, 0, 0 },
                //    { 0, "Sales expenses", 500, 630, 0, 0 },
                //    { 0, "Taxes", 350, 375, 0, 0 },
                //    { 0, "Utilities", 400, 370, 0, 0 },
                //    { 0, "Other", 500, 435, 0, 0 },
                //    { 0, "Total Expenses", 0, 0, 0, 0 }
                for (int row = 4; row < rowsTurnos; ++row)
                    for (int col = 1; col < 7; ++col)
                        sheet.Cells[row, col].Value = data[row - 4, col - 1];
                sheet.FpSpread.AllowUserFormulas = true;
                TableView table = sheet.AddTable("tblOperatingExpense", 4, 1, rowsTurnos, 6, TableStyle.TableStyleLight1);
                //sheet.Cells[15, 3].Formula = "Sum($D$6:$D$15)";
                //sheet.Cells[15, 4].Formula = "Sum($E$6:$E$15)";
                //sheet.Cells[15, 5].Formula = "Sum($F$6:$F$15)";
                /*for (int row = 5; row < 15; ++row)
                    sheet.Cells[row, 1].Formula = "IFERROR([ACTUAL] / [BUDGET], \"\")";
                    sheet.Cells[row, 5].Formula = "[BUDGET] - [ACTUAL]";
                    sheet.Cells[row, 6].Formula = "IFERROR([DIFFERENCE ($)] / [BUDGET], \"\")";
                //fpSpread1.ActiveSheet.SetFormula(iRowCount + 1, 8, "SUM(I1:I" + iRowCount + ")");
                sheet.Cells[rowsTurnos, 6].Formula = "SUM(G4:G" + rowsTurnos + ")";
                //sheet.Cells[15, 6].Formula = "IFERROR($F$16 / $D$16, \"\")";
                //2DA Consulta
                OleDbParameter oDate1b = oCommand.Parameters.Add("@date1", OleDbType.VarChar);
                OleDbParameter oDate2b = oCommand.Parameters.Add("@date2", OleDbType.VarChar);
                OleDbParameter sParam1b = oCommand.Parameters.Add("@sParam1", OleDbType.VarChar);
                OleDbParameter sParam2b = oCommand.Parameters.Add("@sParam2", OleDbType.VarChar);
                OleDbParameter sParam3b = oCommand.Parameters.Add("@sParam3", OleDbType.VarChar);
                oDate1b.Direction = ParameterDirection.Input;
                oDate2b.Direction = ParameterDirection.Input;
                sParam1b.Direction = ParameterDirection.Input;
                sParam2b.Direction = ParameterDirection.Input;
                sParam3b.Direction = ParameterDirection.Input;
                oDate1b.Value = dateTimePicker1.Text.Replace(" p.m.", "");
                oDate2b.Value = dateTimePicker2.Text.Replace(" p.m.", "");
                sParam3b.Value = "";
                sParam1b.Value = "";
                sParam2b.Value = "2";
                turnosDA2 = new OleDbDataAdapter();
                turnosDA2.SelectCommand = oCommand;
                DataSet dsTurnosb = new DataSet("rtpTurnos");
                turnosDA2.Fill(dsTurnosb);
                var rowsTurnosB = dsTurnosb.Tables[0].Rows.Count;
                object[,] dataB = new object[rowsTurnosB, 7];
                int x2 = 0;
                try
                    foreach (DataRow row in dsTurnosb.Tables[0].Rows)
                            dataB[x2, c] = row.ItemArray[c];
                        x2++;
                // 4 + el tamaño de el array
                int iRow2 = rowsTurnos + 4;
                for (int row2= 0; row2 < rowsTurnosB; ++row2)
                    iRow2++;
                TableView table2 = sheet.AddTable("tblOperatingExpense2", rowsTurnos+4, 1, rowsTurnosB, 6, TableStyle.TableStyleLight1);
                //sheet.Cells[rowsTurnosB, 6].Formula = "SUM(G4:G" + rowsTurnosB + ")";
  • Posted 30 October 2019, 8:09 pm EST - Updated 30 September 2022, 1:42 pm EST
    I need one table and another one below
  • Posted 31 October 2019, 1:30 am EST
    Could you please check the row and column count of sheet before this code:
                    iRow2++;
    If it show less number of row or column, please increase the row and column count as follow:
    sheet.Rows.Count = 7;
    sheet.Columns.Count = 7;
    Hope it helps.
  • Posted 31 October 2019, 1:24 pm EST - Updated 30 September 2022, 1:42 pm EST
    is the same error
  • Posted 1 November 2019, 1:12 am EST
    The problem is in dataB array. row2 value starts from 0. if you subtract 4 from row2, it gives the -4 value which causes this exception. Please try with the modified code:
                    sheet.Cells[iRow2, col].Value = dataB[row2, col - 1];
                iRow2++;
    Hope it clarifies.
  • Posted 1 November 2019, 3:09 pm EST - Updated 30 September 2022, 1:42 pm EST
    Yes I can do
  • Posted 1 November 2019, 3:10 pm EST - Updated 30 September 2022, 1:42 pm EST
    I receive this error when I leave the application open
  • Posted 1 November 2019, 3:51 pm EST
    How can I add a header to TableView?
  • Posted 1 November 2019, 6:18 pm EST
    It is show like this
    ```[img]https://gccontent.blob.core.windows.net/forum-uploads/file-d6d48749-7c4c-4c3b-916b-154f22cbce54.jpg[/img]
  • Posted 1 November 2019, 7:19 pm EST
    I found How to change name of columns with
    table2.SetColumnNames(new string[] { "some", "some"......
  • Posted 4 November 2019, 4:42 am EST
    I think your issue is resolved now. If you are still getting the error while closing the application then could you please share the stripped-down application with us. Are you trying to dispose the element in form close event?
  • Posted 5 November 2019, 3:56 pm EST
    how can I cleared the query results for second query
  • Posted 5 November 2019, 10:13 pm EST - Updated 30 September 2022, 1:42 pm EST
    I can cleared with fpSpread.ActiveSheet.Reset();
    but I can’t hide header on creation of PDF
  • Posted 6 November 2019, 1:38 am EST
    You can specify that only a range of cells within a sheet prints, rather than the entire sheet. After specifying the range of cells with the PrintInfo object, use the PrintSheet method as described in Printing an Entire Sheet. Please refer to the following link:
    https://help.grapecity.com/spread/SpreadNet12/WF/webframe.html#spwin-printrange.html
