Posted 11 June 2021, 2:47 am EST
Hi Team,
In my desktop client case there is 25k rows and 16 + column. I just need to hide zero values rows and I’m iterating a loop and checking the zero value for each column for every iteration. and its almost taking 6 min so please suggest the suitable solution for this.
form.SuspendSpreadLayout();
ReportArea area = (ReportArea)areaOperations.Area.UserInterfaceData;
if (area.CustomData)
return;
int startRow = area.DataBeginRow; int endRow = area.AreaEndRow; int sheetNo = area.SheetNo; Sheet reportSheet = dataDefinitionParser.GetSheet(sheetNo); IList<int> udidCols = areaOperations.GetDefinitionColumnUdidPositions(); form.SheetAutoCalculation(sheetNo, false); for (int i = startRow; i <= endRow; i++) { row = i; if (isHeaderRow(sheetNo, row, udidCols)) continue; if (IsZeroRow(areaOperations, sheetNo, row)) { if (area.HiddenRowsDone == false && !form.RowVisible(sheetNo, row)) { //Put row to hidden rows collection if (!reportSheet.HiddenRowsTable.Contains(row)) reportSheet.HiddenRowsTable.Add(row); } if (!reportSheet.HiddenRowsTable.Contains(row)) //Don't do anything to originally hidden row if (state) { //Hide row form.HideRow(sheetNo, row); //Add zero row to zerorowstable if (!reportSheet.ZeroRowsTable.Contains(row)) reportSheet.ZeroRowsTable.Add(row); } else { //Show row, must check rowset if (reportSheet.DefaultRowSet || reportSheet.SelectedRowSet.MarkedRows.Contains(row)) form.ShowRow(sheetNo, row); } } else if (!reportSheet.HiddenRowsTable.Contains(row) && (reportSheet.DefaultRowSet || reportSheet.SelectedRowSet.MarkedRows.Contains(row))) form.ShowRow(sheetNo, row); } if (state) //Show active row, hidezerorows may cause unvisible rows if (form.GCSpread == null) form.ShowRow(0, form.ActiveRow, VerticalPosition.Center); area.HiddenRowsDone = true; form.ResumeSpreadLayout(); form.SheetAutoCalculation(sheetNo, true);
and IsZeroRow is:
int col = areaOperations.Area.DefinitionColumns.Count;
Sheet sheet = dataDefinitionParser.GetSheet(sheetNo);
foreach (DATADEF.DataColumn column in areaOperations.Area.DataColumns.GetDataColumns())
if (column.DataField == null)
continue;
if (sheet.SubTotalRowPositions != null && sheet.SubTotalRowPositions.Count > 0 && sheet.SubTotalRowPositions.Contains(row)) { zeroRow = false; break; } if (column.DataField.Type == DataFieldType.Numeric || column.DataField.Type == DataFieldType.Formula) //Check if other than zero { //alternative to get number object o = formHelper.GetObjectFromSheet(sheetNo, row, col); if (!double.TryParse(o.ToString(), out n)) n = 0; if (n != 0) { zeroRow = false; break; } } else if (column.DataField.Type == DataFieldType.Comment) { //Comment, ignore col++; continue; } else { //Extra data //Check length string value = formHelper.GetStringFromSheet(sheetNo, row, col); if (value.Length != 0) { zeroRow = false; break; } } col++; } form.ResumeSpreadLayout();
