How to Increase Row Number column Width
Posted by: ankur-jain on 8 September 2017, 2:59 pm EST
  • Posted 8 September 2017, 2:59 pm EST
    In my spread sheet Row number upto 999 Row number column is ok but the row number digit in 4 digit like (1000) so sheet show this number in  separate way (100 in one line and 0 in different line).
    so i want to re-size  or customize  (Increase) Row number column width. so 4 or more than 4 digit come in one line.........
    Thanks in advance
    You would need to set the WordWrap property of the RowHeader to false, so that it does not displays the labels in two lines and later set the width of the column in the RowHeader using the GetPreferredWidth method. This method returns the width i.e. necessary to accomodate the label in the RowHeader. Here is the code for the same:
    private void button1_Click(object sender, EventArgs e)
       FarPoint.Win.Spread.CellType.EnhancedRowHeaderRenderer rhr = new FarPoint.Win.Spread.CellType.EnhancedRowHeaderRenderer();
       rhr.WordWrap = false;
       fpSpread1.Sheets[0].RowHeader.DefaultStyle.Renderer = rhr;
       fpSpread1.Sheets[0].RowHeader.Columns[0].Width = fpSpread1.Sheets[0].RowHeader.Columns[0].GetPreferredWidth();
    Hope it will help you. Please let me know if you have any queries further.
    Manpreet Kaur
    you just use for loop which is starts from your usage(its maybe 1000 or 10000)
    You need not use any loops as the code suggested above would work for any number of digits in row header.
    Manpreet Kaur
  • Posted 17 September 2018, 10:44 am EST
    Hello. Excuse me resurrecting this old thread but I came across it because it’s what I need to do. However, in this forum I often come across answers that reference Farpoint.Win.Spread whereas my application uses Farpoint.Web.Spread. Quite often their members are different. My question therefore is twofold: Firstly, what method should I be using for Web? Secondly, why do I always come across this disparity? Is it because that’s what most people use? Could answers not include both Web and Windows methods? Thanks for clearing up my confusion!
