Issue with ComboBoxCellType in Windows Server 2012 OS
Posted by: sudidela on 8 September 2017, 3:00 pm EST
    Posted 8 September 2017, 3:00 pm EST
    I have an issue with  the ComboBoxCellType. when i click on combobox, dropdown gets displayed with the list of values and goes off in no time. so there is no time for the user to select a value in the dropdown. This issue exists in Windows 8 Operating System only. It works well with Windows 7 OS.
    It would be great if any one helps me out of this ?
    Ravindranath
  • Posted 8 September 2017, 3:00 pm EST
    Thanks Manpreet for your prompt reply.
    Our version of Farpoint spread is Spread.Net  v5.0.3511.2008. We are getting this issue in WIndows 8 operating system machine having Visual Studio 2008.
    Ravindranath
    I tested the issue with latest version of Spread i.e. Spread.Net6 v6.0.xx05 on a Windows 8 operating system machine and Visual Studio 2012 but I was not able to replicate the issue at my end. I have attached a video that depicts the same, please let me know if I missed something. I would also like to know which version of Spread are you currently using. However, I was able to notice that on clicking on the cell with celltype set to ComboBoxCellType for the first time, it displays the list correctly, but once you select a value and again click on the cell while the cell is in edit mode, it does not displays the list again but changes the value in the cell if I click anywhere in the area where the list would have displayed. Please share your observations on the same.
    Manpreet Kaur
    2012/09/video.zip
    I would suggest you to test the issue with the latest version of Spread for Windows Forms 5 i.e. v 5.0.xx22 to see if it resolves the issue that you are currently facing. You can download the same from the following link:
                       ftp://ftp.fpoint.com/SpreadWinForms5/
    Hope it will help you. Please let me know if you have any queries further.
    Manpreet Kaur
    I dont have development environment having Windows 8 OS installed. Even we dont have access to the Testing environment system to install other versions of Windows Far Point Spread. So can you please try simulating this issue at your end by installing the Spread of version what we have been using (v5.0.3511.2008) in Windows 8 OS and let me know if this occurs at your end as well. ?
    Ravindranath
    I would need some time to setup the environment at my end. I would soon share my observations with you.
    Manpreet Kaur
    I was not able to replicate the issue at my end. Please have a look at the attached sample created on Windows 8 using Spread for Windows Forms v 5.0.3511 in VS 2008. I would request you to modify the attached sample to depict your issue so that I can replicate the same at my end and debug it further.
    Manpreet Kaur
    2012/09/combotest3511.zip
    Hi Manpreet,
    I have seen your sample application and everything looks same almost. There is nothing i can modify in your code to depict the issue. But i have one point to say.
    The environment where this issue found is Win8 desktop windows 2012 server and it is a testing domain. No visual studio development environment (having win8 desktop and windows 2012 server) exists to debug or play around with the code to simulate the issue or to resolve the issue.
    Note:
    Issue doesn't exists in windows server 2008 64 bit OS. Issue exists in Windows server 2012 64 bit OS.
    Ravindranath
    I have escalated the issue to the development team, I would let you know as soon as I get any information in this regard.
    Manpreet Kaur
    Hi Manpreet,
    I have got the chance to test the sample application that you have sent in our testing domain (windows server 2012 OS) by placing your application's exe and i could able to simulate the issue that we have been discussing about. So it is clear from our end that there is an issue with ComboBoxCellType. Please let me know your view on this.
    Ravindranath
    The development team is trying to replicate the issue at their end but have not succeeded with the same yet. I would update you on the issue, as soon as I get any information in this regard.
    Manpreet Kaur
    Hi Manpreet,
    Any update on the issue?
    Ravindranath
    The issue has been reported as a bug to the development team and the bug number for the same is #99929631. It would be fixed in the next maintenance release of Spread which is expected to be released in mid of December.
    Manpreet Kaur
    The development team is not able to reproduce the issue at their end and are seeking this information further, could you please update the thread with the same providing the specific versions and service packs information if any installed:
    We would like to know the following information:
    1. Version of .NET framework.
    2. OS version.
    Looking forward to your cooperation.
    Manpreet Kaur
    I would like you to know that the development team is not able to replicate the issue at their end with the latest version of Spread i.e Spread.Net6 v 6.0.xx05. So, I would suggest you to test the issue with the same at your end to see if you are able to replicate the issue with the latest build. You can download the same from the following link:
                 http://www.gcpowertools.com/DownloadLatestVersion
    Manpreet Kaur
    Hi Manpreet,
    I have downloaded the latest version of Spread.Net v 6.0.3506.2008 and placed the spread control in the sample application that you have posted earlier and tested in my system having the environment of windows 7 32 bit OS. There is no issue in this environment. Even before there was no issue. The issue still exists in Windows server 2012 64 bit OS environment.
     Can you please confirm with your developement team in what environment they tried to simulate the issue ?
    Please let me know if you need the video file through which the simulated issue can be seen ?
    Ravindranath
    The development team was trying to simulate the issue on Windows Server 2012 machine. However, I have updated the bug with the latest information provided by you and have escalated the issue to the concerned team. I would let you know as soon as I get any information in this regard.
    Manpreet Kaur
    Hi Manpreet,
    Do you have any update on this. This issue has been in place since long time. Could you please look into this ?
    Ravindranath
    Unfortunately, I do not have any update on this issue currently. I have again requested the development team for a workaround for this issue. I would update you as soon as I get any information in this regard.
    Manpreet Kaur
  • Posted 5 November 2020, 5:39 am EST
    I see this comment above . Actually we are also facing the same problem . Any fix ?
    Please note this issue is infrequent and happening only on our remote servers which is windows server
    It is not happening when I am running the code from my local system which is windows 10
  • Posted 10 November 2020, 1:44 am EST
    Hi Ankit,
    It seems like you have created a duplicate post for the same. So, I have replied here: https://www.grapecity.com/forums/spread-winforms/issue-with-comboboxcelltyp_1
    And please try to avoid creating multiple posts for the same query as it might lead to confusion.
