Posted 21 October 2019, 5:43 am EST
I encounter a problem when recalculating a sheet with RecalculateAll ().
The method should force the re-evaluation of all cells in the Sheet.
However, if a formula is sufficiently far from the area of the sheet displayed, it is not reevaluated.
To illustrate this problem you will find a project attached.
The sheet contains a custom formula in cell row 136 column AE.
The next scenario to reproduce the problem is simply to recalculate the document using the button launching RecalculateAll ().
A breakpoint is set on the re-evaluation procedure of the custom formula RIK_AC. We should see that the breakpoint is reached when opening the document, but not when clicking Recalculate.
In addition, if you run the recalculation and then scroll to the row of the cell containing the formula (136), its re-evaluation will be triggered …
Apprenez à prononcer
So my question is does the RecalculateAll() method compartmentalize the re-evaluation of sheet cells?
And how to get around the problem?
Thanks for your help.
Best Regards.
